Is there another option other than using an adapter on my Sportsman? It has an integrated 1 1/4" receiver that looks to be part of the machine. Not bolted on. I would rather have a 2" since there are more accessory options using a 2". An adapter will make the hitch extend out quite a bit. Bolting or welding something on the bottom will eat up ground clearance. Anyone have a solution?
all the options are avail on a 1 1/4 hitch... not as popular but out there..2 inch is too big and heavy duty for what your going to pull with a quad
You can also search item # 170814030181. This is what I have on my Sportsman, but I have the "tab with a hole" factory hitch. Is there anywhere on your's to bolt this to?
Thanks for the replies. Looks like an adapter is the only way to go. I do like that moose adapter. Thats probably gonna be the one.
