Hey guy's, Needing some help on an 08 SP 800. The crazy thing is, its only in
4x4 Hi or Low under hard acceleration, ether full throttle or pulling something. The "check engine" light will come on, but as soon as you let out of the throttle, the light will go off. I read the code and its a 25, Transmission Input-Invalid Gear. I've tried pushing or pulling on the gear selector while under acceleration with no luck, light still comes on. I have read about a connector I should check, people say sometimes water can get in and cause a poor connection. can anyone tell me what connector this is and its location? Also what are some other things I need to check or test to get to the bottom of this? Thanks in advance!!
