1 - 8 of 8 Posts
Have a 2013 sportsman 500 shifter shift into all gears but will not go into gear. Son was riding and it went out of gear riding on rode. could this be the gear sensor???
No - the gear sensor simply provides a signal so the display indicates what gear it's in - it's either a shifter or transmission problem
some times the plastic unions snap. is there any resistance in the shifter??
Checked fluid and its level it will shift into different gears with shifter. What about checking side with belt and clutch. Would that make it just go out of gear while driving.
tranny shouldn't jump gears under any situation. chk and make sure the tranny is actually being shifted as the bell may be stripped.
1 - 8 of 8 Posts
