Hey! I was wondering if anyone on here would know the solution to an issue that I'm having with my machine. The quad is a 1999 Sportsman 500 and it had a problem today. I had the throttle just about maxed in low range and was not moving. I assumed the belt was slipping because it had been left outside in the rain for a few days, and there was a bit of water coming out of the CVT cover, but then even after the CVT was dried, it was still having the same issue. Like it would start going across a field, then I would give it any amount of throttle and it would make a noise then slow right down as if it was in neutral. And then it will randomly kick back in and then the engine braking will just about throw you over the handle bars. Anyone ever have this problem? I assume it's the belt that's just about to go or the clutch is gone. Idk what it is anyone have advice? Thanks in advance
