I have a set of long ramps. they are safe and very tough. they're expensive, but well worth the money. they will last me the rest of my life. they are built by the company that makes diamondback truck covers.after reading some of the posts with truck loading mishaps sounds like tri fold ramps are the way to go?
those ramps would be scary unloading out of a very tall truck. especially on unlevel ground. 6ft is kinda short unless you own a small pickup or are loading them on a trailer. I bought the 8.5 ft long folding ramps so I could load in the bed of my 3/4 ton truck whether on level ground or not. plus, mine are heavy enough to use with my ranger.These HF models work fine for me. Just make sure you are dead on and you will be fine as they are right at perfect width.
If you don't own tri-folds how can you advise on them? I have owned both and know for a fact the tri-folds are much safer and faster. I can attach my trifold in less than a minute and I don't ever have to worry about making sure my ramps are aligned or hooked correctly to the truck or if they will slide. Once they are racheted to the hitch (with a single rachet strap) you can't pull them off the truck if you tried. Mine are like 65" long and about 54" wide and I can load and unload my large 850 XP that is 55 inches wide at the tires with complete focus on operating the ATV rather than worrying if the ramps are aligned correctly or if they are going to slide around on me. The "Don't Ask' thread is the incorrect use of ramps and have nothing to do with them being tri-folds. I'm glad you like using two ramps but they are not safer or better than tri-folds. Buy a set and then you will have a different opinion.I do not have them and have had no problems with using the standard ramps. Usually when there is an accident involving ramps, it has nothing to do with the ramps.
Having that center section between the ramps provides only minimal safety if you drive off of the ramps on an atv. Trifolds are great for motor cycles and loading equipment you have to walk next to or behind.
Take a look at the "Don't Ask" thread. he used trifold ramps.
I have owned both kinds (including several single ones) and have loaded equipment of all sorts and for ATV's, riding lawm mowers and other 4 wheel equipment the Tri-Folds are the best. You don't have to adjust them as they fit all the way accross the width of the tail gate / truck bed if you buy the correct width. You don't have to line up your tires with a Tri-Fold. You don't have to strap down two ramps to somewhere on your truck which is difficult with two single ramps. You want to buy them long enough so you don't have a steep angle but thats the same for both single or tri-folds. You said you had little experience with tri-folds but were happy to dispel them as unsafe junk based on pictures which is why I was so "bold" in my statement. Not trying to get into a Pi$$ing contest just wanting to make a point based on my experience with both types of ramps.wow man you have a strong opinion. the long ramps will hold more weight and fold to fit in a short bed truck. so in some ways they're superior. plus, the trifolds limit you to only the width of the trifold. I can move my ramps to whatever width I want. to each his own. but i always wince at guys that make bold statements with out knowing about all the products out there.
Had to check my post as I am getting older. Nope never said that I never owned or never used trifold ramps. I said I now have single ramps and have had no issues.If you don't own tri-folds how can you advise on them? I have owned both and know for a fact the tri-folds are much safer and faster. I can attach my trifold in less than a minute and I don't ever have to worry about making sure my ramps are aligned or hooked correctly to the truck or if they will slide. Once they are racheted to the hitch (with a single rachet strap) you can't pull them off the truck if you tried. Mine are like 65" long and about 54" wide and I can load and unload my large 850 XP that is 55 inches wide at the tires with complete focus on operating the ATV rather than worrying if the ramps are aligned correctly or if they are going to slide around on me. The "Don't Ask' thread is the incorrect use of ramps and have nothing to do with them being tri-folds. I'm glad you like using two ramps but they are not safer or better than tri-folds. Buy a set and then you will have a different opinion.I do not have them and have had no problems with using the standard ramps. Usually when there is an accident involving ramps, it has nothing to do with the ramps.
