Discussion Starter · #2 ·
Chassis solenoid clicks fast will not turn over. unpluged it and motor turns over but will not start. swapped with new one no change. must be electrical, at a total loss for solution. worked fine then total crash. could it be the ECU?
Try cleaning and di electric greasing cables at battery, you replaced the solenoid so you've already done it, follow wires , aunplug , clean and grease all plug ins from battery to ign switch, What model ranger is it, 500-7-8--?
