Unable to shift “help”
2K views 4 replies 3 participants last post by  lateburd
I’m not 100% familiar with the 2000 xplorer 250 4 x 4 as far as gear shifting.
I’m assuming the idle Has to be low enough to allow it to fall into H or R or L gear similar to our go kart clutch?
#2 ·
Yes rpm has to be low enough the belt isn't engaging the secondary. Assuming it shifts with the machine off??
Reactions: Scrappy507
#4 ·
Ok so its either high idle or mis-aligned clutches.
