I am rebuilding a 700 twin and the motor was flooded thanks to IKE. If the motor cannot be repaired i was wondering if it could be upgraded to the 800 motor in that year model. Just checking to see if anybody has tried or any suggestions on the matter. Thanks.
We offer a 800 motor kit for your 700. The kit comes with everything you need to convert your 700 to the 800. If you are looking for more power we have a awesome camshaft, bored throttle body, head porting, reprogrammed ecu, and clutching to put all that power to the ground. You can check it out at www.dirtydawgperformance.com or call 651-340-1129.
Thanks Dale
