I went to an auto parts store and got the connector on both ends in the trailer/rv section of the place. I cut the wire in half so I have two pig tails.
Thanks, will check it out!
No problem. A search online will sometimes calls it a two way flat plug. Usually 12 volt. you'll see both ends match that plug. Like I said, I cut it in half and spliced one into a 12 volt flashing light and another to a spolight. I keep them both in the cargo box and when I need them, i just plug them in. If you do much in water or mud, I suggest putting some dielectric grease in there and cleaning from time to time.
