Hi my wheeler came with a year old Polaris 54" V-plow. I was hoping to find a manual or some parts list/picture. I have a loose bolt with some type of plate floating around and not one on the other side. Here is a pic
That block or plate as you call it is used to set the vertical angle of the blade.
You can adjust the angle that works best for you. There should be an identical block on the other side also. Both blocks should be set the same way and tightened down.
not being tight is probably why yours is missing one...
Great Thanks!! It was missing a spring too, which I ordered from dealer. Guess Ill order another block and bolt. I'm new to wheelers and plows so these terms are new to me lol. Anybody have a pic of it installed properly? Here is another pic of plow. Anything else missing other than what I know.
