1 - 12 of 12 Posts
If I wanted to lift my 400HO 2", would I need new axles? Would the new axles be stock length, or longer?
Thanks Jay. Will the rear axles bind or be under more pressure with a 2" lift?
Yes, everything will be under more pressure. The only thing I have broken thus far has been CV's, mainly the outer ones and in the front.
So what can you do to relieve the pressure to avoid snapping an axle?
Not do the lift :).
Or replace your a-arms, axles, etc... with parts that are going to handle the additional abuse.
When you install a lift you increase the angle of axils to the cv joints. I don't think there is a fix for that other than installing heavy duty axils & cv joints, Gorilla, Rihno, Highlifter. Taller tires is an option vs the lift.
Yeah, 500HO here, I lifted for a matter of 2 months. Broke 2 CV Joints. Went back to stock. IMO - dont bother lifting. Get some nice tires (go 26-27s with your 400). you will be golden
Thanks guys.
If I go to a 26" or 27" do I need to re-clutch? What about if I went 26"-27" on 14" rims, will the stock clutch be ok?
if you go to bigger tires (regardless of the rim) you're putting the strain on the drive system (usually the belt) instead of the cv joint. There's ALWAYS a trade-off. if you upgrade to a kevlar belt you ought to be fine assuming you're really good about maintenance and using really good oils. Also, with bigger tires you'll lose acceleration.
Discussion Starter #11
Thanks Mugzy. I am a stickler with maintenance. Maybe a 26" tire on the 12" rim would be the waay to go?
If you're spending the money 'cause you need new tires anyway. Remember, every additional inch in tire diam only gives you a 1/2" of additional ground clearance. Nothing beats good riding skills.
1 - 12 of 12 Posts
