1 - 2 of 2 Posts
2003 Polaris Magnum 330 4x4 Someone please enlighten me to the color code for the In/Ex stem seals please, Rebuild kit/ service manual non specific
I have 1 Black and 1 reddish/brown..
3084858Seal, Intake Valve
3084859Seal, Exhaust Valve
No specification on the seal by part number, but the exhaust valve stem is slightly smaller in diameter than the intake - test fit the seals on the exhaust valve and use the tightest fitting one on it and the loose fitting one will be for the intake
137025
Intake stem is .0002 to .0007 (ten thousandths) of an inch larger than the exhaust or .005 to .020 (thousandths ) of a mm - the seals may work perfectly fine on either valve, but may not fit the top of the guide - seals I have installed were green on both intake and exhaust - I guess it depends on what brand gasket set you are using. If you buy them from Polaris, they will come in packages with the corresponding numbers on them.
I do not have any in my inventory, so I can't pull them for inspection
1 - 2 of 2 Posts
