stamped into the lower frame rail in the left front wheel well behind the tire, on the square tubing that angles out from the a-arm mount to the width of the tire. it is small dots that make up the vin. also on that year it might be on a sticker on the side of the radiator cover in the right front wheel well. and also can look in the rear of the machine, some had a sticker with the vin# on the upper sway bar dead center of machine. vin should be 17 digits
