Looking for the vin number on a 96 magnum 425 4x4 the original manual says on rh side of upper frame rail under seat there is nothing there. there is a warning sticker on the crossbar in the corner is 7072791which may be a vin otherwise on the shifter there is model:1341127 serial:95-02373
Can anyone help me so I can get new registration
Mine had the VIN on the headlight cover (sticker), and on the frame in the right front corner. If you looked in the right front wheel well, it was in the top left corner near where the gear shifter is located. The VIN on the '96 is only a 7 digit number.
Hope this helps.
I dont know what year mine is vin is 2931635
Here's the info on you machine:
Model Name - MAGNUM 2X4
Model Year - 1996
Model Number - W967544
Purchase Date - 10/9/1996
VIN - 2931635
Engine Serial Number - 9609644
Warranty
Warranty
Factory Warranty
Start Date - 11/4/1996
Expiration Date - 4/9/1997
7072791 is the part number for the air filter decal - NO LONGER AVAILABLE for purchase - was used on various 89-2000 models.
None of the other numbers come up as a part or VIN
What state are you in? Check with the DMV and use the legal process to obtain a title and registration. Why do you need to register it?
