Is there any way to get more speed and power out of my 2017 sportsman 570. Any tricks I can do? Mods? Programmers?
138187
Go chk out RVSPerformance, they have tunes, exhausts, and clutch kits. They even have complet kits you can get that are labeled as "stages" from wild the ones that require exhaust, intakes, and premium fuel.
Clutch kits are always a good solid improvement, pretty cheap and easy to install.
Which clutch kit would you recommend for more speed? I'm mainly riding trails and gravel roads. I also do a little bit of mudding.
I think you need to get rid of the ATC185 - would you consider it?
I would definitely consider parting with it. I bought it a few months ago with the intentions of using it alot but then I found this sportsman and haven't really messed with it.
The preferred clutch kit is QSC quad sport customs.
