I recently installed a Warn RT25 Winch on my Sportsman 500 HO. when i press the in/out button the contactor/Solinoid clicks but the motor does not run. Could this be more and likely a defector contactor/soliniod?
test procedure
Hi there , assuming you have it wired correctly , put a meter { set to dc volts } or a 12 volt light on the two winch posts , it you get power when you hit the switch I would have to deduce you have a defective winch , if you get no power at the winch posts when you hit the switch you have a defective solenoid , or the solenoid is incorrectly wired .
Good luck , let us know how you make out .
