I need a mechanical seal but am going riding this weekend, nogt sure if seal weill get here in time. would plugging that weeping hole be ok for riding it afew hours or rad stop leak work?
I'd be afraid to plug the hole, for fear of the cooling system building up enough pressure , to leak past the faulty seal, then leak past the oil seal and into the bottom-end.
Try stop leak first, if that doesn't work .............It's your machine.
I am going to try the stop leak to see if i make it for riding just a few hours. Its dripping but not bad so ill just do sxhort rides and refill if the stop leak does not work
yea its not like a trail ride that is long just going to bomb around on some property in ny with easy access to stop and monitor the level so it will be fine, unless the magicaL seal comes in the mail today
