1 - 15 of 15 Posts
I tried to find anything about water pump seal on other forums with no luck and decided to ask in here, at specific model XP. Recently I had water pump seals issues and looks like there is something with my bad luck >? coincidence >? riding style >? or what else >? I do have 3 XPs all different years and engines, 850 , 850ho and 1000. In all of them water pump seal failed, it happen on different mileage too: 2300, 700, 1200. ? what am I doing wrong with these XPs? Does anyone else had any problems with their WPS"?
The only thing I'm thinking of to prevent this is not to shut off machine while fan is running? but will this solve my issue , I know I were doing it in all of them but I doubt it could be a problem. Storage indoor or outdoor is not an issue too... then what else it could be?
geez, i though the wps was more of a 500 model issue, !!! how many miles on the 1000 ?
so far im good with my 2 quads, i always let them run until the fan turns off if its running when i stop, remember to put it in park not to glaze the drive belt .
Any 60/40 or 50/50 mix of Green ethylene glycol antifreeze/coolant , and that's straight from the dealers service manual.
"Polaris recommends the use of Polaris Premium 60/40 antifreeze/
coolant or a 50/50 mixture of high quality aluminum
compatible anti-freeze/coolant and distilled water"
"Recommended Coolant
Use only high quality antifreeze/coolant mixed with distilled
water in a 50/50 or 60/40 ratio, depending on freeze protection
required in your area."
Aluminum compatible - read silicate free or low silicate
Use whatever you want - I've yet to have a water pump seal fail and I use the recommended coolants exclusively. I do not necessarily use Polaris coolant, but I use Honda Type I or Type II (only difference is color - Type I is green Type II is blue and they can be mixed), Maxima Coolanol (green) and Engine Ice (blue) regularly in my ATV's and motorcycles. I experiment and switch coolants from time to time - I have Honda Type II in my CRF, Honda Type I in my VT1100 Shadow and Engine Ice in my Roketa 200 ATV. Not sure what is in my 06 Trailboss 330 as I have not worked on the engine and have not changed the coolant - it's blue and it is probably the Polaris 60/40 coolant, but it will be Polaris 2880513 50/50 (since they discontinued the 2871323 60/40) the first time I have to drain and refill the system.
Don't know what manual you are looking at, but here's page 44 of the service manual publication 9928503 for 2018 Sportsman 850/1000.
I have never seen a Polaris manual that recommends any coolant other than POLARIS brand coolant.
2012 and 2013 Sportsman 550XP Polaris factory service manual
Yeah, it says Polaris Premium or a "high quality aluminum compatible" antifreeze.
It does NOT say use "any" antifreeze.
Of course "not required" but use of their (or other product) specifically manufactured for use in their vehicle may benefit in reduced maintenance and repair cost. Would you use gasoline engine coolant in a diesel engine? Most diesel engines specify a specific coolant depend on the service the engine is expected to perform and the construction (wet sleeve vs dry sleeve).
If you don't know the difference, go back to engine school and ask for the chapter you slept through. The science of coolant (and oil) has all changed in the last 10 years.
Do you realize you are starting to embarrass yourself. My reply was simple, you can use automotive antifreeze. I doesn't have to be branded polaris. Do you actually think polaris manufactures their own antifreeze? Now to find the block user function.
Discussion Starter #13
1200miles on 2016xp1000. and just notice it start passing little through that small hose from the "alternator cover"... I'm pretty sure they all had org. fluids from factory/dealer... I have never drain any coolant so has to be "factory". All were green . How many miles on yours XPs ?
if we skip what fluid manual recommend, and look for anything about keep'n machine running till fan shuts off , is that recommended in manual ? I think problem could be right there...
i've got 2500 miles on my 2016 1000,
about same mileage on the 570, i don't think manual says to let them cool down but it was recommended to me by my dealer a long time ago when i had 500's and i warped the clutch cover.
Disposable parts they told me when i mentioned the axles were so small now days compared to the old 500's , !!!!
Oh stop. I think you can understand my reply.
LOL, yeah I know asbuilt. I may need to check mine I guess. I've got around 1600 on my 2018. I haven't noticed any drips on the garage floor or the reservoir getting low but I might need to look closer after seeing this.
1 - 15 of 15 Posts
