Hi! Anybody here who knows if there is any Connections or so needs to be disconnected before welding on the machine?
Polaris 850XP -12
Polaris 850XP -12
I have welded with and without the battery or ecu connections disconnected. I would always suggest placing your ground as close to the weld as possible to protect any potential issues..I always disconnect batteries and cod any time I'm welding on anything.
How do i disconnect cdi/Engine Control unit?I always disconnect batteries and cdi any time I'm welding on anything.
As long as both battery cables are disconnected, you will be fine.How do i disconnect cdi/Engine Control unit?I always disconnect batteries and cdi any time I'm welding on anything.
Polaris 850XP -12
Sure, can not hurt.Factory service manual stated to always disconnect the ECM. Its an additional fifteen minutes to disconnect it so why not?
Where do I find this Connection?Factory service manual stated to always disconnect the ECM. Its an additional fifteen minutes to disconnect it so why not?
x2, left side the airbox, should have a metal housing on it with a Bosch sticker I believe.Sorry jgcoastie's
That is the voltage regulator/rectifier
The ECU is mounted on the left side of the air box under the plastic
Oops... Appears I was wrong! Thanks for posting that correction Vibe!Sorry jgcoastie's
