Attempting to drain the counter balance oil but a few ounces of green fluid came out. The plug is on the bottom just forward of the starter. It's a 10mm plug with a Phillips slot. Angled about a 45 degrees compared to the floor. After closer inspection it appear to below the output shaft to the primary clutch. I think the counter balance oil drain plug is a few inches closer to the centerline. Any ideas on what and where to fill the green fluid from?
-'97 Sportsman 400L 2 Stroke-
Discussion Starter #2
It was the crankcase drain. Unless I'm wrong the oil pump supplies the crankcase oil gallery from the 2 stroke oil tank. So crisis adverted.
Why don't you lift the seat and see what the counter balancer reservoir has in it? It holds 3 ounces and it independent of the rest of the oiling system. Luck! :cowboy:
