1 - 20 of 28 Posts
Welcome to the board!
From what I've seen, 28s if you don't want them to rub. I got a buddy about to try to stuff 30s under his, I'll let you know how that works out.
I really like the mega mayhems. I had them on my foreman 450 and will be putting them on my 570 and ranger in the near future
I have 28" silverbacks on mine and I dont think I could go any bigger with out rubbing.
I have the 28 mega mayhems on my 550 XP and absolutely love them! They dig great, and my bike is still reasonably sporty. I am gonna be ordering a clutch kit fir mine soon though, just because I don't want to put too much strain on the belt.
This is a picture of my 27" tires. If the shocks arent fully tightened they rub on really rough terrain, but Im 5'11" and 247Lbs. Hope that helps!
Discussion Starter #11
Thanks for all the info... now here is another question im not really big on the rims and all so would it be better to use the factory rims for now or just go ahead with the cheaper itp rims??
Factory wheels may not work because they are offset to the inside to keep all the wheel under the bike. More than likely a bigger wider tire will rub on factory wheels. Aftermarket, throws the wheel out more, giving you a little more room
IDK about the standard quad, but my 570 with 26" ripsaws rubs in the rear if i compress the suspension too much. I haven't yet discovered what its rubbing but its somewhere.
I have 28" mega mayhem's on stock rim about 1/4" clearance from front tie rod
We have 28in mega mayhems on Sedona wheels, rears rub with 2 people on it. But the shocks are turned all the way down cause she likes the softer ride.
I had 27's on my 2015 570 sp touring and had to get 26's because they were rubbing the foot support for the rear rider. No amount of stiffening the suspension made a difference.
I have 28 mega mayhems on my 570 with msa wheels No rubbing at all
your biggest thing is going to have to be looking at getting a set of wheels or spacers to clear the struts in the front and i believe some one on this forum has 30in zillias on a pretty much stock 570, I have 27in zillas on mine with plenty of room and i am no little guy
I've got 28in mega mayhems and they fit without any mods only 4+3 rims.
1 - 20 of 28 Posts
