1 - 11 of 11 Posts
the white on im pointing to its underneath the headlight harness. what is this plug and what does it do and where should it connect? my 12v acc outlet is wont work and keeps blowing the acc fuse and im wondering if this might have something to do with it? please help
That's a live 12v cable or better known as an accessory plug. It's used to power up the rocker switch for the winch or whatever you might have in mind like a radio.
I've been told that is a diagnostic port, never tested it for power.
I have seen several winch installation instructions and they use that port to provide power to the rocker switch. Guess it can serve multiple purposes.
The orange single wire is a 12v accessory plug. The white plastic plug is a diagnostic port for the dealer to plug in the Digital Wrench program.
I knew I was right, I even called my local dealer and they told me that same thing you just said.
He says "the white on im pointing to" .
1 - 11 of 11 Posts
