what kind of brakes do you guys recommend? i do mostly trail riding and hills, but everynow & then theres a puddle, creek, or mud that you just feel the need to go through! lol what kind of brakes do you guys think are good? stock or more if heavy duty sand, water and mud ones? also plan to get a new rotor too, its a little bent. THANKS!
EBC is what I use!
EBC Severe Duty pads. I ride a lot of mud and they seem to hold up pretty good.
Since disc brakes are so easy to change. I purchase the cheapest pads I can find. Last ones I bought were clearance items $8.00 per axle. Work just as well as original. Have not worn them out yet.
hatcoleman has a point...I've used the elcheapo's on some of the bikes I fix for friends and they often actually stop better than the severe duty pads but won't last nearly as long. If you keep a close eye on them and don't mind changing more often they work just fine.
