Think I blew a head gasket and I need new a radiator on my 2018 sportsman 450.With all the necessary flushes and what not,What kinda bill should I expect from a dealer?
What flushes? Is coolant in the oil? Is it under warranty? If not, look for an independant shop.
$1500/$1800 in today's dealer prices
Don't understand why you'd need a new radiator because you blew a head gasket? I'm also wondering about what would cause a head gasket to fail on a two year old machine?
And what "flushes" are you talking about?
Maybe a little more explanation is needed.
If you simply had some some coolant in the oil just change it. Then change again after a few hours of run time.
2015 Sportsman XP 1000 LE Touring
Reactions: Sprotsman
Lookup how to replace both on YouTube and save ur cash. Both are relatively easy to do with common tools. But if ur not comfortable, yes the dealer will be ‘spensive. Good luck brother
buy a factory service manual, will make life easier, especially with overhead cams.
