Preventive maintenance.
2018 Polaris Sportsman 850 Touring SP
57 hours. 300 miles.
Tomorrow. Changing fluids early. Meant to do around 25 hours
Spark plugs this weekend when they come in.
Sad you have to pull plastic for that crap.
- polaris oil filter and 5W-50 full synthetic.
- pulled rear wheels and hubs and used aftermarket wheel bearing greaser.
- pulled rear skid. finally able to see the grease fittings and lube. Custom cut drain holes.
- cut Pre marked drain holes in my Iron Baltic skid plates. Going to be much easier to keep clean.
- pulled belt cover (what FPITA that is. Have to remove plastics also if you want to change belt. Belt looked brand new. Not even dust or shavings in the cover. No evidence of water intrusion.
- cut front skid to access tow hook. Might work, probably not a big enough hole.
- pull front wheels and pack bearings
- lube all front grease fittings
- change rear diff fluid
- change front diff fluid
- change transmission fluid
- change ADC fluid.
- button her back up so my wife can have her side of the garage back
