301 - 320 of 340 Posts
Discussion Starter · #301 ·
Good thing you started a maintenance thread then.
Pics or did not happen my good sir.
Sent from my LG-SP200 using Tapatalk
Well once I learned that the Polaris and Can-Am mini ATVs are simply Chinese or other Asian knock offs, I figured why spend twice as much?
Discussion Starter · #303 ·
It’s on the boat.
or o the pier.
Reactions: MrEd
anyone cover their CVT intake? worried more about mice than anything....I DOUBT they built a nest and that touring makes it a PITA to pull the cover.
and one more, when riding, my radiator gets full of seeds and fluff from plants. Every 10 minutes or so I have to clear it off. No joke.
Thoughts?
If you want to cover the CVT ducting, try some frogzskin
I've got nothing on the radiator issue
Sent from my SM-G970U using Tapatalk
2022 Highlifter 850 w/Camco X4s
97 Polaris 500 sportsman 4x4 Indepedent shaft drive, 2000 Honda 450S foreman
aaaand I pulled the trigger on a chinese 200cc EFT machine...three disc brakes too (not a fourth)
It’s like for a little 1?…there’s a local dealer near me that sells em. The worst part of them really is how they come assembled you really just have to give the whole bike a once over before you ride it all bolt thread locker where needed check for snugness make sure bolts are not under or over torqued check fluids gaskets throttle brake levers clutch etc. otherwise you get what you pay for it and for the most part other not that terrible no it’s not at 800 or anything like that but it’ll do the job …
Discussion Starter · #310 ·
Yes, he's 11 and a lightweight.
Hammers the piss out of his 2020 cold-blooded POS CANAM DS70.
disc brakes get me excited.
So does the EFI....
only because I am sick of dealing with the DS70
ENGINE
Engine Make / Type Air-Cooled SOHC 4-Stroke 176cc
Top Speed35MPH
Lubrication TypePressure and Hybrid Splash Lubrication
Max Torque 10N·m/6000r/min
Compression Ratio 9.5:1
Valve Configuration2 Valve
TRANSMISSION & DRIVE
Drive TypeFully Automatic
GearsCVT – F,N,R
Clutching TypeAutomatic Centrifugal Dry
Drive line TypeChain
Starting SystemElectric Start
SUSPENSION
Front SuspensionSingle A-Arm
Rear SuspensionRear Single Shaft Swing Arm
BRAKES, TIRES & WHEELS
Front/Rear BrakesDisc Brakes
Front Tire20×7-10
Rear Tire19×10-9
Front/Rear Tread820mm / 810mm
MEASUREMENTS & DIMENSIONS
ATV Dimensions 63'(L) x 41'(W) x 41'(H)
Ground Clearance5.9in
Wheelbase45in
Discussion Starter · #311 ·
Discussion Starter · #313 ·
Rat wire?
Discussion Starter · #314 ·
Im glad we don’t have rodents isssue here,,just cold, snapped my fuel pump, injection & crank/cam position sensor grounds on ny. Pickup today tightening the damn timing cover/water pump housing I left it fried 2 ign fuses with remote start n called it, found problem tho the truck was fine until iccranked the bolts, the ground was onca stud that holds power steering pump reservoir and it made 2 pcs of okd wire n exposed copper touch arcing out ill cut splice and solder tomorrow sometime was too aggravated…o yea the funny part, go to my garage to get the polaris to use lights to work in and there was a damn fox in mt garage laying on my craftsman fender mat that was on garage floor in front of quad. Started it and this bastard vertical leaped about 7 ft somehow used me as footing mid air and was gone before I realized almost shat my pantaloons 🤣….glad I didn’t get bit haha
So does the EFI....
ENGINE
Engine Make / TypeAir-Cooled SOHC 4-Stroke 176cc
Top Speed35MPH
Max Torque10N·m/6000r/min
Compression Ratio9.5:1
GearsCVT – F,N,R
SUSPENSION
Front Tire20×7-10
Rear Tire19×10-9
ATV Dimensions63'(L) x 41'(W) x 41'(H)
Wheelbase45in
Cvt too…belt n clutches lol id b nervous there maybe
Discussion Starter · #318 ·
Discussion Starter · #319 ·
I have never had a rodent problem. Now she’s in the garage where rodents aren’t authorized.
Where do you live @Nitroman78
We get them bad in the fall, soon as it starts getting cold. I buy boxes of mothballs, throw a few in a zip lock bag with a dryer sheet and leave them around the shed/garage/equipment. Makes a big difference.
Sent from my SM-G991U using Tapatalk
