1 - 20 of 25 Posts
Tell us what winch you run!
If you're shopping around for a winch for your ATV CLICK HERE or check out a couple of our best sellers below.
Superwinch Terra 35 Winch With Cable Rope
Standard Features
  • Powers Load IN and OUT.
  • Automatic 100% load holding brake.
  • Full metal, 3-Stage Planetary Gear-train.
  • Ergonomic Freespooling Clutch.
  • High efficiency, low amp draw, sealed permanent magnet motor.
  • Circuit Breaker Protected.
  • Weather Sealed Solenoid Contactor.
  • 4-way Roller Fairlead.
  • Heavy Duty Latched Hook with Thimble.
MotoSport.com Price: $295.99
Warn Vantage 3000 Winch
Vantage 3000: More pulling power for larger ATVs and side x sides. When you need big power at a premium value, the Vantage 3000 is an excellent choice for vehicle recovery or moving heavy loads. With great performance, a powerful motor, and 3,000 pounds of pulling capacity, this winch will get the job done without breaking the bank.
  • 50' of 3/16" wire rope with roller fairlead.
  • Fully sealed motor and drivetrain to keep the elements out.
  • Three-stage planetary gear train for smooth, efficient operation.
  • Mechanical spring brake for control while winching.
  • High-strength composite gear housing and all-metal gears.
  • Includes handlebar-mounted mini-rocker switch and corded remote control.
  • Warranty: 5 year mechanical, 1 year electrical (North America).
MotoSport.com Price: $307.99
I'm running a warn a2000 on my 2001 sportsman 400 upgraded with a contactor solenoid and using a wireless winch remote from ebay
Sent from my HTC Incredible S using Tapatalk 2
I am using a 2500 pound Polaris winch with a steel cable on the back and a 3500 pound Polaris HD winch with a synthetic rope on the front. Both remotely controlled by Polaris's wireless remote.
I've ran SuperWinch #2500 in the past, great winch!
Currently running a Pure Polaris #2500 on the 2012 Sportsman800 & a Warn #2500 on the 2005 Sportsman 400.
Warn 2500
Warn XT30
Warn 2500. It came with wire rope, but I have switched over to synthetic rope.
warn rt 3.0 upgraded to a synthetic rope and aluminum haus fairlead.
Milemarker 2500 ES, wish I had gone with the super winch terra.
4000 lb Viper Max with synthetic
1 - 20 of 25 Posts
