1021 - 1040 of 1044 Posts
27 inch Pro Armor Dagger tires with Rockstar wheels! 27x9x14 in front and 27x11x14 in the rear.
Wheels are 3.5+3.5 (zero offset). Wide stance for the wide trails out here is no problem! These look like the Mega Mayhems, but the Pro Armor are 8 ply radial, compared to the Mayhems 6 ply bias. I wanted a radial tire really bad, so I was fine with spending the extra money for these!
How do those bighorns hold up for you I've thought about using them since my buddy has them on his RZR and says there plenty for the basic mudding we do.
Just installed a set of Quad Boss QBT672 radials in 26x12x12 and 26x9x12 on some Vision Buckshot 158 wheels. Wheels are 12x8 (4+4) rear and 12x7 (4+3) front. Tires ride smooth for as aggressive as they are, tire pressure is at 3.5lbs rear and 4.5lbs front. Here are a few pics.
Tire stickout is about equal F to R, definitely gonna need some fender extensions...
Tie rod clearance
Hiper Sidewinder Beadlocks (Carbon Fiber hubs / Billet Aluminum centers) In 14X7 - 4+3 offset.
14X9 front /14X11 rear GBC Grim Reaper tires.
2017 Polaris Sportsman XP 1000
Stock Rims with 28-10-14 STI Outback Max tires all around
Damn man... that 17 stealth black 1k with that set up on it is perfect. that might be one of the best looking sportsmans I ever seen in my life. Congrats on a beautiful bike!
Did some tire swapping this weekend. Gonna have to add 1" spacers but should be interesting to see how it runs.
Put some 28" outlaws on my king quad so needed a new home for my 27" Kenda Executioners. Rub the swaybar in the rear and tierod in the front.
2001 Sportsman 500ho DUSE now with 27x10x12 front 27x12x12 rear on stock wheels with 2" lift.
2019 sportsman xp1000
ranger 1000 stock steel wheels 12x6 offset around 5x1
27x9x12 maxxis zillas
I had to grind down the brake calipers and use 1/4" wheel spacers to get the 12" rims to fit.
135858
135859
135860
I made a discussion in the wheel/tire section outlining how to make the 12" rims fit on an XP chassis for those that are curious.
