1041 - 1060 of 1096 Posts
2020 Polaris Sportsman Premium Trail Edition
  • 27" Interco Sniper 920's
  • System 3 SB-4 Beadlock rims (in stock Polaris 6+1 offset)
136475
136476
Looking to put 26×9-12 and 26×11-12 on a 2017 sportsman 570. Do they rub on stock rim if they do what cheap rims should i buy.
Yes they'll rub in the front on the tie-rod ends. You can get ITP steel rims for $49.99 or some people use a spacer with the oem rim.
Reactions: Corbett1973
2015 Sportsman XP 1000 LE Touring
I have the rims/tires and machine below.
The back of my front rim states 14"*5.5".
I have a set of Roctane XD's that are 26"*9"*14".
Can I put the Rocktanes on my stock rims?
Will there be any rubbing? (Fenders, tie-rods or such) I can't get much wider as trailer space is limited, so I hope I won't need a spacer.
139791
139792
2021 Sportsman 850 Premium
For you guys with the 28" HTR's...
What is the ACTUAL height of the tire, and at what PSI are you at when measuring?
EDIT - Found a couple posts where guys say they measure true to size.
I like those wheels. How much pressure are you running?
I loved the look of them and read tons and tons of great reviews. I'm taking them out for the first time this weekend. The shop installed them and put 7 PSI in them as recommended on the side of the tire. They have some squish to them but I may lower it down to 5 as a lot of reviews said the ride and performance was on point. We'll see how the ride first on my machine. As you can see in the picture, I don't have bead locks so I don't want to take them down too low and risk popping off the rim.
I got them off of Amazon for $484 shipped. It was the best deal I could find anywhere plus if there was a problem, it was backed my Amazons return policy. I bought the 28" inch since they filled out my 850 nicely without having to buy bigger rims, a clutch kit, or spacers. In playing around in my backyard a bit, they didn't rub and there is plenty of room before they do. My shocks are set all the way up.
I have 2K miles on mine and they still look new....
Wheel Tire Land vehicle Vehicle Cloud
