1061 - 1080 of 1096 Posts
My 2018 850 has 26x8x14 front, 26x10x14 rear. what is a good size to put on and not have problems or spacers???? 27' or 28" and how wide?
1995 magnum 425 4x4 2019 sportsman 570 2020 sportsman 850
I put 28” bearclaw HTRs on mine with no spacers or clutch mods. I have a 2016 850 SP and shes a pure beast with them.
Do they wobble at speeds above 45ish?
Depending on what you ride in, sand, mud, trails, I would go with a 28" tire, the more clearance under the quad the better. Maybe stay with the same width, just a little taller, I dunno.
I would call the stock tires pillows, Bearclaws are stiff
Reactions: Pamm
I just bought 27x9x14 front and 27x11x14 for rear, just one size larger so should be ok. I have been told that my clutch has been adjusted but I don't how to tell. I know it starts to roll at about 2100 rpm, it that normal or has it already been reset?
Unsure about you clutch tip in rpm is, that sounds close to my 1000. How does the power feel, no rolling in gear at a stop, right?
26s are a perfect balance of clearance and stability. They look great!!!
Reactions: bobx2 and Rob 55
So you replaced 26" OEM with 26" aftermarket tires... The new ones look SO MUCH BIGGER?
