1 - 20 of 21 Posts
Hey guys. Need to change out at least my front wheel bearings and a arm bushings on my 12 sportsman. I have seen several different types online.
The one that seems to be the best deal is all balls!! Does anyone have experience with this all balls brand? I know they are a overseas knock off but I have read good and bad reviews. Anyone have any experience with these on sportsmans?
If they are junk, what else are you recommending?
I have had good luck with all balls in my ranger
Allballs, boss bearing, and quad boss are all about the same. I tried epi once and because I was in a pinch I installed a set of their rear bearings well they didn't have seals, needless to say those bearing failed quick.
As for bushings Jccapri a member on here makes stout set. I think you can order them through his company PV3.com. Heard garage products makes good bushings as well.
Actual bearing brand would be Timken/fafnir. American made and the best out there. Oe brand on my 99 sportsman and still going strong! Other quality bearing brands are SKF, nachi, nsk, ntn, koyo, fag. These have been around forever and most of these brands are japanese. Maybe all of them. I wouldnt buy any bearing with china on it. Even romanian bearings are better. You could get the number off your bearing and shop it from an actual bearing shop and know what brand you are getting. Prob cheaper too. Cheap bearings may be ok in a quad, most of my experience is with cars, sleds, and industrial equipment
Those are for his '12 800 Sportsman, they fit ALOT of other models as well. Parts breakdowns list the sizes of bearings, just takes some time searching around to find the right ones. I think it's even the same rear as far back as my '99 and nearly all the front bearings since they switched from the Hilliard hubs...i will paste in model fitments tomorrow from my computer if someone hasn't by then.
Discussion Starter #11
This is awesome info guys!! Appreciate the help. I will for sure look local for these bearings now
Discussion Starter #12
Oh BTW, For the rear bearings, how much play in them before you should change? Mine move a little but nothing like my fronts.
My first couple of wheel bearings I was changing with only minimal movement. Now they have to have 1/2" or more play.
Polaris 3514634, 35X64X37mm. Front. Crosses to Timken 510014, cheapest from RockAuto at $40 plus shipping.
NATIONAL 510014 Wheel Bearing | RockAuto
2001 A01CD32AA MAGNUM 325 4X4 FRONT STRUT
2001 A01CD32AA MAGNUM 325 4X4 SWING ARM-REAR-GEARCASE MOUNTING
2001 A01CD32AB MAGNUM 325 4X4 MOSE FRONT STRUT
2001 A01CD32AB MAGNUM 325 4X4 MOSE SWING ARM-REAR-GEARCASE MOUNTING
2001 A01CD32FB 325 MAGNUM 4X4 HDS FRONT STRUT
2001 A01CD32FB 325 MAGNUM 4X4 HDS SWING ARM-REAR-GEARCASE MOUNTING
2001 A01CD50AA MAGNUM 500 SWING ARM-REAR GEARCASE MOUNTING
2001 A01CD50FB 500 MAGNUM 500 HDS FRONT STRUT
2001 A01CD50FB 500 MAGNUM 500 HDS SWING ARM-REAR GEARCASE MOUNTING
2002 A02CB32AA MAGNUM 325 2X4 SWING ARM-REAR GEARCASE MOUNTING
2002 A02CB32AB MAGNUM 325 2X4 SWING ARM-REAR GEARCASE MOUNTING
2002 A02CB32FC 325 MAGNUM 2X4 HDS SWING ARM-REAR GEARCASE MOUNTING
2002 A02CB50FC MAGNUM 500 2X4 HDS SWING ARM-REAR GEARCASE MOUNTING
2002 A02CD32AA MAGNUM 325 4X4 SWING ARM-REAR GEARCASE MOUNTING
2002 A02CD32AB MAGNUM 325 4X4 SWING ARM-REAR GEARCASE MOUNTING
2002 A02CD32AC MAGNUM 325 4X4 FREEDOM SWING ARM-REAR GEARCASE MOUNTING
2002 A02CD32FB 325 MAGNUM 4X4 HDS FRONT STRUT
2002 A02CD32FB 325 MAGNUM 4X4 HDS SWING ARM-REAR GEARCASE MOUNTING
2002 A02CD50AA MAGNUM 500 FRONT STRUT
2002 A02CD50AA MAGNUM 500 SWING ARM-REAR GEARCASE MOUNTING
2002 A02CD50AB MAGNUM 500 RMK FRONT STRUT
2002 A02CD50AB MAGNUM 500 RMK SWING ARM-REAR GEARCASE MOUNTING
2002 A02CD50FB 500 MAGNUM VL HDS FRONT STRUT
2002 A02CD50FB 500 MAGNUM VL HDS SWING ARM-REAR GEARCASE MOUNTING
2002 A02CH68AA-AB-AC-CA-CB SPORTSMAN 700 FRONT STRUT
2002 A02CK32AA XPEDITION 325 SWING ARM-REAR GEARCASE MOUNTING
2002 A02CK42AA-AB XPEDITION 425 SWING ARM-REAR GEARCASE MOUNTING
2002 C02CD50AC ATV PRO 500 4X4 PPS FRONT STRUT
2002 C02CD50AC ATV PRO 500 4X4 PPS SWING ARM-REAR GEARCASE MOUNTING
2003 A03CB32AA MAGNUM 330 2X4 SWING ARM-REAR-GEARCASE MOUNTING
2003 A03CD32AA-AB-AC-FB MAGNUM 330 4X4 FRONT STRUT
2003 A03CD32AA-AB-AC-FB MAGNUM 330 4X4 SWING ARM-REAR GEARCASE MOUNTING
2003 A03CD50FB 500 MAGNUM 4X4 HDS FRONT STRUT
2003 A03CD50FB 500 MAGNUM 4X4 HDS SWING ARM-REAR-GEARCASE MOUNTING
2003 A03CH59AA SPORTSMAN 600 FRONT STRUT
2003 A03CH68AA-AC-AF-AH-AL SPORTSMAN 700 FRONT STRUT
2004 A04CB32AA MAGNUM 330 2X4 SWING ARM-REAR-GEARCASE MOUNTING
2004 A04CD32AA MAGNUM 330 4X4 FRONT STRUT
2004 A04CD32AA MAGNUM 330 4X4 SWING ARM-REAR-GEARCASE MOUNTING
2004 A04CH42AQ SPORTSMAN 400 FRONT STRUT
2004 A04CH50AQ SPORTSMAN 500 FRONT STRUT
2004 A04CH59AF SPORTSMAN 600 FRONT STRUT
2004 A04CH59AK SPORTSMAN 600 FRONT STRUT
2004 A04CH68AC SPORTSMAN 700 FRONT STRUT
2004 A04CH68AK SPORTSMAN 700 FRONT STRUT
2004 A04CH68AU-CU SPORTSMAN 700 FRONT STRUT
2004 A04JD32AA ATP 330 4X4 FRONT STRUT
2004 A04JD32AA ATP 330 4X4 REAR AXLE
2004 A04JD50AA ATP 500 4X4 FRONT STRUT
2004 A04JD50AA ATP 500 4X4 REAR AXLE
2004 A04RB42AA RANGER 2X4,4X4,6X6 FRONT STRUT
2004 A04RB63AA RANGER TM FRONT STRUT
2005 A05CB32AA MAGNUM 330 2X4 SWING ARM-REAR-GEARCASE MOUNTING
2005 A05CD32AA MAGNUM 330 4X4 FRONT STRUT
2005 A05CD32AA MAGNUM 330 4X4 SWING ARM-REAR-GEARCASE MOUNTING
2005 A05JD32AA ATP 330 4X4 FRONT STRUT
2005 A05JD32AA ATP 330 4X4 REAR AXLE
2005 A05JD32EA ATP 330 4X4 QUAD FRONT STRUT
2005 A05JD32EA ATP 330 4X4 QUAD REAR AXLE
2005 A05JD50AA ATP 500 4X4 FRONT STRUT
2005 A05JD50AA ATP 500 4X4 REAR AXLE
2005 A05MH42AB SPORTSMAN 400 FRONT STRUT
2005 A05MH50AB SPORTSMAN 500 HO-INTL FRONT STRUT
2005 A05MH59AK SPORTSMAN 600 FRONT STRUT
2005 A05MH68AC SPORTSMAN 700 EFI FRONT STRUT
2005 A05MH68AK-AN-AD SPORTSMAN 700 FRONT STRUT
2005 A05MH68AP SPORTSMAN MV7 STRUT, FRONT
2005 A05MH76AC-AU-AW SPORTSMAN 800 EFI STRUT, FRONT
2005 R05RB50AA-RD50AA-AB-AC-AD-RF50AA-AB RANGER 2X4,4X4,6X6 FRONT STRUT
2005 R05RB63AA RANGER TM FRONT STRUT
2005 R05RD68AA RANGER XP STRUT, FRONT
2006 A06CD32AA MAGNUM 330 4X4 STRUT, FRONT
2006 A06CD32AA MAGNUM 330 4X4 SWING ARM, REAR-GEARCASE MOUNTING
2006 A06GP50AA OUTLAW 500 SUSPENSION, REAR
2006 A06LB27AA HAWKEYE 2X4-4X4 STRUT, FRONT
2006 A06LB27AA HAWKEYE 2X4-4X4 WHEEL, REAR and HUB, REAR
2006 A06LB27FA HAWKEYE 2X4-4X4 INTERNATIONAL STRUT, FRONT
2006 A06LB27FA HAWKEYE 2X4-4X4 INTERNATIONAL WHEEL, REAR and HUBS
2006 A06MH46AA SPORTSMAN 450 STRUT, FRONT
2006 A06MH50AA SPORTSMAN 500 HO STRUT, FRONT
2006 A06MH50AQ SPORTSMAN 500 EFI STRUT, FRONT
2006 A06MH50FB SPORTSMAN 500 HO INTL STRUT, FRONT
2006 A06MH50FC SPORTSMAN 500 EFI INTL STRUT, FRONT
2006 A06MH68AA SPORTSMAN 700 STRUT, FRONT
2006 A06MH68AQ SPORTSMAN 700 EFI STRUT, FRONT
2006 A06MH76AL SPORTSMAN 800 EFI STRUT, FRONT
2006 A06MN50AU SPORTSMAN X2 STRUT, FRONT
2006 R06RB50AA RANGER 500 2X4-4X4 STRUT, FRONT
2006 R06RB63AA RANGER TM STRUT, FRONT
2006 R06RD50AC RANGER 500 4X4 EFI STRUT, FRONT
2006 R06RD68AA RANGER XP 4x4 700 STRUT, FRONT
2006 R06RF68AA RANGER 6x6 EFI 700 STRUT, FRONT
2007 A07GP50AA-AB OUTLAW 500 SUSPENSION, REAR
2007 A07GP52AA-AB OUTLAW 525 SUSPENSION, REAR
2007 A07LB27AA-AC-LH27AA-AB-AC-AD-AL HAWKEYE 2X4-4X4 STRUT, FRONT
2007 A07LB27AA-AC-LH27AA-AB-AC-AD-AL HAWKEYE 2X4-4X4 WHEEL, REAR and BRAKE DISK-HUBS-BEARING CARRIERS
2007 A07LB27FA-LH27FB HAWKEYE 2X4-4X4 INTL STRUT, FRONT
2007 A07LB27FA-LH27FB HAWKEYE 2X4-4X4 INTL WHEEL, REAR and HUB, REAR
2007 A07MH46AA-AZ SPORTSMAN 450 SUSPENSION, STRUT, FRONT
2007 A07MH50AB-AL-AQ-AX-AY-AZ-MN50AF-AN-AT-AY SPORTSMAN 500 EFI SUSPENSION, STRUT, FRONT
2007 A07MH50FC SPORTSMAN 500 EFI INTL SUSPENSION, STRUT, FRONT
2007 A07MH68AX-AY-AZ SPORTSMAN 700 EFI SUSPENSION, STRUT, FRONT
2007 A07MH76AL-AQ-AX-AY-AZ-A2-MN76AF-AT-AY SPORTSMAN 800 EFI SUSPENSION, STRUT, FRONT
2007 A07MH76FA SPORTSMAN 800 EFI INTL SUSPENSION, STRUT, FRONT
2007 A07TH50AL-AQ-AU-AZ-TN50AF-AS-AU SPORTSMAN X2 500 EFI STRUT, FRONT
2007 A07TH50EA SPORTSMAN X2 500 EFI QUAD STRUT, FRONT
2007 A07TH76AU-TN76AF-AL-AU SPORTSMAN X2 800 EFI STRUT, FRONT
2007 R07RB50AA-RH50AA RANGER 500 2X4-4X4 STRUT, FRONT
2007 R07RF68AD-AF RANGER 700 EFI 6X6 STRUT, FRONT
2007 R07RH50AF-AR-AT RANGER 500 EFI 4X4 STRUT, FRONT
2007 R07RH68AD-AG-AH-AK-AL-AO-AP-AW RANGER 4X4 700 EFI-LE STRUT, FRONT
2008 A08DN50AF-AS-AW-AZ SPORTSMAN TOURING 500 EFI SUSPENSION, FRONT STRUT
2008 A08DN50EA SPORTSMAN TOURING 500 EFI QUAD SUSPENSION, FRONT STRUT
2008 A08DN76AF-AG-AH-AL-AJ-AS SPORTSMAN TOURING 800 EFI SUSPENSION, FRONT STRUT
2008 A08DN76FC SPORTSMAN TOURING 800 EFI INTL SUSPENSION, FRONT STRUT
2008 A08GP52AA OUTLAW 525 IRS SUSPENSION, REAR
2008 A08LB27AA HAWKEYE 2X4 SUSPENSION, FRONT STRUT
2008 A08LB27AA HAWKEYE 2X4 WHEELS, REAR
2008 A08LH27AW-AX-AZ SPORTSMAN 300 4X4 SUSPENSION, FRONT STRUT
2008 A08LH27AW-AX-AZ SPORTSMAN 300 4X4 WHEELS, REAR
2008 A08LH46AQ-AX-AZ SPORTSMAN 400 HO 4X4 SUSPENSION, FRONT STRUT
2008 A08LH46AQ-AX-AZ SPORTSMAN 400 HO 4X4 WHEELS, REAR
2008 A08MH50AX-AZ SPORTSMAN 500 HO SUSPENSION, FRONT STRUT
2008 A08MH50SS-SQ SPORTSMAN 500 EFI SCANDINAVIAN SUSPENSION, FRONT STRUT
2008 A08MH76SS-SF SPORTSMAN 800 EFI SCANDINAVIAN SUSPENSION, FRONT STRUT
2008 A08MN50AF-AN-AQ-AR-AS-AT-AW-AX SPORTSMAN 500 HO EFI SUSPENSION, FRONT STRUT
2008 A08MN76AF-AL-AQ-AR-AS-AT-AX SPORTSMAN 800 HO EFI SUSPENSION, FRONT STRUT
2008 A08TN50AT-AX-AZ SPORTSMAN X2 500 EFI SUSPENSION, FRONT STRUT
2008 A08TN50EA SPORTSMAN X2 500 EFI QUAD SUSPENSION, FRONT STRUT
2008 A08TN68AX-AZ SPORTSMAN X2 700 EFI SUSPENSION, FRONT STRUT
2008 A08TN76AA-AQ SPORTSMAN X2 800 EFI LE SUSPENSION, FRONT STRUT
2008 R08RB50AA RANGER 500 2X4 SUSPENSION, FRONT STRUT
2008 R08RF68AD-AF-AZ RANGER 6X6 700 EFI SUSPENSION, FRONT STRUT
2008 R08RH50AF-AR-AT RANGER 4X4 500 EFI SUSPENSION, FRONT STRUT
2008 R08RH68 RANGER 4X4 700 EFI-XP ALL OPTIONS SUSPENSION, FRONT STRUT
2008 R08WH68AG-AH-AK-AR RANGER 4X4 700 EFI CREW SUSPENSION, FRONT STRUT
2009 A09CL76AA SPORTSMAN 800 EFI 6X6 SUSPENSION, FRONT STRUT
2009 A09DN50AB-AZ SPORTSMAN TOURING 500 EFI SUSPENSION, FRONT STRUT
2009 A09DN50EA SPORTSMAN TOURING 500 EFI QUAD SUSPENSION, FRONT STRUT
2009 A09DN76AB-AL-AY SPORTSMAN TOURING 800 EFI SUSPENSION, FRONT STRUT
2009 A09DN76FC SPORTSMAN TOURING 800 EFI INTL SUSPENSION, FRONT STRUT
2009 A09GP52AA OUTLAW 525 IRS SUSPENSION, REAR
2009 A09LB27AA HAWKEYE 300 2X4 SUSPENSION, FRONT STRUT
2009 A09LB27AA HAWKEYE 300 2X4 WHEELS, REAR
2009 A09LH27AX-AZ SPORTSMAN 300 4X4 SUSPENSION, FRONT STRUT
2009 A09LH27AX-AZ SPORTSMAN 300 4X4 WHEELS, REAR
2009 A09LH46AQ-AX-AZ SPORTSMAN 400 HO 4X4 SUSPENSION, FRONT STRUT
2009 A09LH46AQ-AX-AZ SPORTSMAN 400 HO 4X4 WHEELS, REAR
2009 A09MH50AS-AX-AZ SPORTSMAN 500 HO SUSPENSION, FRONT STRUT
2009 A09MN50AN-AX SPORTSMAN 500 EFI SUSPENSION, FRONT STRUT
2009 A09MN50ET SPORTSMAN 500 EFI TRACTOR SUSPENSION, FRONT STRUT
2009 A09MN76AX-AZ SPORTSMAN 800 HO EFI SUSPENSION, FRONT STRUT
2009 A09TN50AX-AZ SPORTSMAN X2 500 EFI SUSPENSION, FRONT STRUT
2009 A09TN50EA SPORTSMAN X2 500 EFI QUAD SUSPENSION, FRONT STRUT
2009 A09TN76AL-AX-AZ SPORTSMAN X2 800 EFI SUSPENSION, FRONT STRUT
2009 R09RB50AF RANGER 2X4 500 CARB SUSPENSION, FRONT STRUT
2009 R09RF68AF-AR-AZ RANGER 6X6 700 EFI SUSPENSION, FRONT STRUT
2009 R09WH68AC-AG-AH-AL-AR-AZ RANGER 4X4 700 EFI CREW SUSPENSION, FRONT STRUT
2010 A10CL76AA SPORTSMAN 800 EFI 6X6 SUSPENSION, FRONT STRUT
2010 A10DH50AX-AZ SPORTSMAN TOURING 500 HO SUSPENSION, FRONT STRUT
2010 A10DH50FX SPORTSMAN TOURING 500 HO INTL SUSPENSION, FRONT STRUT
2010 A10EA32AA TRAIL BOSS 330 SUSPENSION, A-ARM and STRUT MOUNTING
2010 A10EA32FA TRAIL BOSS 330 INTL SUSPENSION, A-ARM and STRUT MOUNTING
2010 A10GP52AA OUTLAW 525 2X4 IRS SUSPENSION, REAR
2010 A10LB27AA HAWKEYE 300 2X4 SUSPENSION, FRONT STRUT
2010 A10LB27AA HAWKEYE 300 2X4 WHEELS, REAR
2010 A10LH27AX-AZ SPORTSMAN 300 4X4 SUSPENSION, FRONT STRUT
2010 A10LH27AX-AZ SPORTSMAN 300 4X4 WHEELS, REAR
2010 A10LH46AX-AZ SPORTSMAN 400 HO 4X4 SUSPENSION, FRONT STRUT
2010 A10LH46AX-AZ SPORTSMAN 400 HO 4X4 WHEELS, REAR
2010 A10MH50AJ-AX-AZ SPORTSMAN 500 HO SUSPENSION, FRONT STRUT
2010 A10MH50FX-FF SPORTSMAN 500 HO INTL SUSPENSION, FRONT STRUT
2010 A10MH76AJ-MN76AX-AZ SPORTSMAN 800 EFI SUSPENSION, FRONT STRUT
2010 A10MN50ET SPORTSMAN 500 EFI TRACTOR SUSPENSION, FRONT STRUT
2010 A10NA32AA TRAIL BLAZER 330 SUSPENSION, A-ARM and STRUT MOUNTING
2010 A10NA32FA TRAIL BLAZER 330 INTL SUSPENSION, A-ARM and STRUT MOUNTING
2010 A10NG50AA SCRAMBLER 500 4X4 SUSPENSION, FRONT STRUT
2010 A10NG50FA SCRAMBLER 500 4X4 INTL SUSPENSION, FRONT STRUT
2010 R10RC08GA-GH-FA-FH RANGER EV-INTL 4X4 SUSPENSION, FRONT STRUT
2010 R10RH45AG-AH-AR RANGER 4X4 400 HO SUSPENSION, FRONT STRUT
2011 A11CF76AA SPORTSMAN 800 EFI 6X6 SUSPENSION, FRONT STRUT
2011 A11DH50AX-AZ SPORTSMAN TOURING 500 HO SUSPENSION, FRONT STRUT
2011 A11DH50FX SPORTSMAN TOURING 500 HO INTL SUSPENSION, FRONT STRUT
2011 A11EA32AA TRAIL BOSS 330 SUSPENSION, A-ARM and STRUT MOUNTING
2011 A11EA32FA TRAIL BOSS 330 INTL SUSPENSION, A-ARM and STRUT MOUNTING
2011 A11GP52AA OUTLAW 525 IRS SUSPENSION, REAR
2011 A11LB27AA HAWKEYE 2X4 SUSPENSION, FRONT STRUT
2011 A11LB27AA HAWKEYE 2X4 WHEELS, REAR
2011 A11MB46FZ HAWKEYE 400 HO 2X4 SUSPENSION, FRONT STRUT
2011 A11MH46AX-AZ SPORTSMAN 400 HO 4X4 SUSPENSION, FRONT STRUT
2011 A11MH50AX-AZ SPORTSMAN 500 HO SUSPENSION, FRONT STRUT
2011 A11MH50FF SPORTSMAN FOREST 500 SUSPENSION, FRONT STRUT
2011 A11MH76AX-AZ SPORTSMAN 800 EFI SUSPENSION, FRONT STRUT
2011 A11MN50ET SPORTSMAN FOREST TRACTOR 500 EFI SUSPENSION, FRONT STRUT
2011 A11NA32AA TRAIL BLAZER 330 SUSPENSION, A-ARM and STRUT MOUNTING
2011 A11NA32FA TRAIL BLAZER 330 INTL SUSPENSION, A-ARM and STRUT MOUNTING
2011 A11NG50AA SCRAMBLER 500 4X4 SUSPENSION, FRONT STRUT
2011 A11NG50FA SCRAMBLER 500 4X4 INTL SUSPENSION, FRONT STRUT
2011 R11RC08GA-GH-FA-FH RANGER EV 4X4-INTL SUSPENSION, FRONT STRUT
2011 R11RC08LG POLARIS LSV 4X4 SUSPENSION, FRONT STRUT
2011 R11RH45AG-AH-AR RANGER 400 HO SUSPENSION, FRONT STRUT
2011 R11RH50AG-AH-AR RANGER 4X4 500 EFI SUSPENSION, FRONT STRUT
2011 R11WH50AG-AH-AR RANGER 4X4 500 CREW SUSPENSION, FRONT STRUT
2012 A12CF76AA SPORTSMAN 800 EFI 6X6 SUSPENSION, FRONT STRUT
2012 A12CF76FF SPORTSMAN FOREST 800 6X6 SUSPENSION, FRONT STRUT
2012 A12DH50AX-AZ SPORTSMAN TOURING 500 HO SUSPENSION, FRONT STRUT
2012 A12EA32AA TRAIL BOSS 330 SUSPENSION, A-ARM and STRUT MOUNTING
2012 A12EA32FA TRAIL BOSS 330 INTL SUSPENSION, A-ARM and STRUT MOUNTING
2012 A12MB46FZ HAWKEYE 400 HO 2X4 SUSPENSION, FRONT STRUT
2012 A12MH46AF-AX-AZ SPORTSMAN 400 HO 4X4 SUSPENSION, FRONT STRUT
2012 A12MH50AD-AO-AQ-AX-AZ SPORTSMAN 500 HO SUSPENSION, FRONT STRUT
2012 A12MH50FF-FX-FY SPORTSMAN FOREST 5OO SUSPENSION, FRONT STRUT
2012 A12MH76AD-AX-AZ SPORTSMAN 800 EFI SUSPENSION, FRONT STRUT
2012 A12MH76FF SPORTSMAN FOREST 800 SUSPENSION, FRONT STRUT
2012 A12MN50ET-EX SPORTSMAN FOREST TRACTOR 500 SUSPENSION, FRONT STRUT
2012 A12NA32AA TRAIL BLAZER 330 SUSPENSION, A-ARM and STRUT MOUNTING
2012 A12NA32FA TRAIL BLAZER 330 INTL SUSPENSION, A-ARM and STRUT MOUNTING
2012 A12NG50AA SCRAMBLER 500 4X4 SUSPENSION, FRONT STRUT
2012 A12NG50FA SCRAMBLER 500 4X4 INTL SUSPENSION, FRONT STRUT
2012 R12RC08GA-GH-FA-FH RANGER EV-LEV 4X4 SUSPENSION, FRONT STRUT
2012 R12RC08LG POLARIS LSV 4X4 SUSPENSION, FRONT STRUT
2012 R12RH45AG-AH-AR RANGER 400 4X4 SUSPENSION, FRONT STRUT
2012 R12RH50AG-AH-AM-AR-AZ RANGER 500 4X4 SUSPENSION, FRONT STRUT
2012 R12WH50AG-AH-AK-AR RANGER 500 4X4 CREW SUSPENSION, FRONT STRUT
2013 A13CF76AA SPORTSMAN 800 EFI 6X6 SUSPENSION, FRONT STRUT
2013 A13CF76FF SPORTSMAN FOREST 800 6X6 SUSPENSION, FRONT STRUT
2013 A13DH50AX-AZ SPORTSMAN TOURING 500 HO SUSPENSION, FRONT STRUT
2013 A13EA32AA TRAIL BOSS 330 SUSPENSION, A-ARM and STRUT MOUNTING
2013 A13EA32FA TRAIL BOSS 330 INTL SUSPENSION, A-ARM and STRUT MOUNTING
2013 A13MB46FZ HAWKEYE 400 HO 2X4 SUSPENSION, FRONT STRUT
2013 A13MB46TH HAWKEYE 400 HO 2X4 HD SUSPENSION, FRONT STRUT
2013 A13MH46AF-AX-MS46AX SPORTSMAN 400 HO 4X4 SUSPENSION, FRONT STRUT
2013 A13MH50AJ-AQ-AX-AZ SPORTSMAN 500 HO SUSPENSION, FRONT STRUT
2013 A13MH50FF-FJ-FU SPORTSMAN FOREST 500 SUSPENSION, FRONT STRUT
2013 A13MH50TD SPORTSMAN 500 HD SUSPENSION, FRONT STRUT
2013 A13MH76AD-AX-AZ SPORTSMAN 800 EFI SUSPENSION, FRONT STRUT
2013 A13MH76FF SPORTSMAN FOREST 800 SUSPENSION, FRONT STRUT
2013 A13MN50ET-EX SPORTSMAN FOREST TRACTOR 500 SUSPENSION, FRONT STRUT
2013 A13NA32AA TRAIL BLAZER 330 SUSPENSION, A-ARM and STRUT MOUNTING
2013 A13NA32FA TRAIL BLAZER 330 INTL SUSPENSION, A-ARM and STRUT MOUNTING
2013 R13RC08GA-GH-FA-FH RANGER 48V EV MIDSIZE-INTL SUSPENSION, FRONT STRUT
2013 R13RH45AG RANGER 400 MIDSIZE SUSPENSION, FRONT STRUT
2013 R13RH50AG-AH-AM-AR RANGER 500 MIDSIZE SUSPENSION, FRONT STRUT
2013 R13RH76AG-AH-AN RANGER 800 EFI MIDSIZE SUSPENSION, FRONT STRUT
2013 R13WH50AG-AH-AR-AX RANGER 500 CREW MIDSIZE SUSPENSION, FRONT STRUT
2014 A14BH33AJ SPORTSMAN ACE SUSPENSION, FRONT STRUT
2014 A14BH33FJ SPORTSMAN ACE EURO SUSPENSION, FRONT STRUT
2014 A14CF76AA SPORTSMAN 800 EFI 6X6 SUSPENSION, FRONT STRUT
2014 A14CF76FA SPORTSMAN 800 EFI 6X6 FOREST SUSPENSION, FRONT STRUT
2014 A14DH57AA-AJ SPORTSMAN TOURING 570 EFI SUSPENSION, FRONT STRUT
2014 A14DH57FJ SPORTSMAN TOURING 570 EFI INTL SUSPENSION, FRONT STRUT
2014 A14MB46TH HAWKEYE 400 HO 2X4 HD SUSPENSION, FRONT STRUT
2014 A14MH46AA-AH-MS46AA SPORTSMAN 400 HO 4X4-SE SUSPENSION, FRONT STRUT
2014 A14MH57AA-AC-AD SPORTSMAN 570 EFI SUSPENSION, FRONT STRUT
2014 A14MH57FA-FJ SPORTSMAN 570 FOREST SUSPENSION, FRONT STRUT
2014 A14MH57TD SPORTSMAN 570 EFI HD SUSPENSION, FRONT STRUT
2014 A14MH5EAA-EAC-EAJ SPORTSMAN 570 EFI EPS SUSPENSION, FRONT STRUT
2014 A14MH5EFJ-EFK SPORTSMAN 570 EFI EPS FOREST SUSPENSION, FRONT STRUT
2014 A14MH76AA-AH SPORTSMAN 800 EFI SUSPENSION, FRONT STRUT
2014 A14MH76FD SPORTSMAN 800 EFI FOREST SUSPENSION, FRONT STRUT
2014 A14MN50EM-EA SPORTSMAN FOREST TRACTOR 500 SUSPENSION, FRONT STRUT
2014 A14MX5ETH SPORTSMAN 570 EFI UTE HD EPS SUSPENSION, FRONT STRUT
2014 R14RC08GD-GJ-FJ RANGER EV MIDSIZE-INTL SUSPENSION, FRONT STRUT
2014 R14RH45AA RANGER 4X4 400 SUSPENSION, FRONT STRUT
2014 R14RH57AA-AC-AR-6EAZ RANGER 570 EFI SUSPENSION, FRONT STRUT
2014 R14RH57FX RANGER 570 INTL SUSPENSION, FRONT STRUT
2014 R14RH76AA-76AC-7EAZ RANGER 800 EFI MIDSIZE SUSPENSION, FRONT STRUT
2014 R14WH57AA-AC-AR-6EAT RANGER CREW 570 EFI SUSPENSION, FRONT STRUT
2015 A15DAA32AA-AJ SPORTSMAN ACE 325 EFI SUSPENSION, FRONT STRUT
2015 A15DAA32EA-EJ SPORTSMAN ACE 325 EURO SUSPENSION, FRONT STRUT
2015 A15DAA57AJ-AH-EAK SPORTSMAN ACE 570 EFI SUSPENSION, FRONT STRUT
2015 A15DAA57EJ-EH-EEK SPORTSMAN ACE 570 EURO SUSPENSION, FRONT STRUT
2015 A15DAH32EJ SPORTSMAN ACE 325 HD SUSPENSION, FRONT STRUT
2015 A15DAH57EJ SPORTSMAN ACE 570 HD SUSPENSION, FRONT STRUT
2015 A15S6A76FA FOREST 800 6X6 SUSPENSION, FRONT STRUT
2015 A15SAA32EH HAWKEYE 325 2X4 SUSPENSION, FRONT STRUT
2015 A15SDA57AA-LJ-E57AJ SPORTSMAN TOURING 570 EFI-EPS SUSPENSION, FRONT STRUT
2015 A15SDA57FH SPORTSMAN 570 EFI TOURING EU SUSPENSION, FRONT STRUT
2015 A15SDA57HH-HA SPORTSMAN TOURING 570 EFI MD SUSPENSION, FRONT STRUT
2015 A15SEA32AA-AH SPORTSMAN ETX EFI SUSPENSION, FRONT STRUT
2015 A15SEA32HA SPORTSMAN ETX EFI MD SUSPENSION, FRONT STRUT
2015 A15SEA57AA-AC-AD-LD SPORTSMAN 570 EFI SUSPENSION, FRONT STRUT
2015 A15SEA57HA SPORTSMAN 570 EFI MD SUSPENSION, FRONT STRUT
2015 A15SEB57CA-CJ-SEC57CJ-CA SPORTSMAN 570 EFI EPS FOREST QUAD SUSPENSION, FRONT STRUT
2015 A15SEE57AA-AC-AJ SPORTSMAN 570 EFI EPS SUSPENSION, FRONT STRUT
2015 A15SEE57HJ-HA SPORTSMAN 570 EFI EPS MD SUSPENSION, FRONT STRUT
2015 A15SEH57AD SPORTSMAN 570 HD SUSPENSION, FRONT STRUT
2015 A15SET57CA-S57CJ-CA 570 EFI-EPS FOREST TRACTOR SUSPENSION, FRONT STRUT
2015 A15SHC57CS SPORTSMAN 570 SP EPS, QUAD SUSPENSION, FRONT
2015 A15SHD57AC-E57AS-AM-L57AK SPORTSMAN 570 SP SUSPENSION, FRONT
2015 A15SHE57HS SPORTSMAN 570 SP MD SUSPENSION, FRONT
2015 A15SHS57CS SPORTSMAN 570 SP EPS, TRACTOR SUSPENSION, FRONT
2015 A15SJE57AS-AV SPORTSMAN 570 SP TOURING SUSPENSION, FRONT
2015 A15SJE57HI 570 TR PRM PS MD SUSPENSION, FRONT
2015 A15SUH57AH SPORTSMAN 570 EFI UTE HD SUSPENSION, FRONT STRUT
2015 A15SWE57AA-AD SPORTSMAN 570 EFI X2 EPS SUSPENSION, FRONT STRUT
2015 A15SWE57FA SPORTSMAN 570 EFI X2 EPS EUROPE SUSPENSION, FRONT STRUT
2015 R15RMA32AA-AJ RANGER ETX SUSPENSION, FRONT STRUT
2015 R15RMA32FA RANGER ETX EU SUSPENSION, FRONT STRUT
2015 R15RMA57AA-AR-AZ-AC-LA-H57AR RGR 570 SUSPENSION, FRONT STRUT
2015 R15RMA57FA RGR 570 EU SUSPENSION, FRONT STRUT
2015 R15RMAE4GJ-GC-EJ RANGER EV SUSPENSION, FRONT STRUT
2015 R15RNA57AA-AC-AR-E57AS RGR 570 EFI CREW SUSPENSION, FRONT STRUT
SERIES 10 A10RB42AA RANGER (SERIES 10) FRONT STRUT
SERIES 10 A10RD50AA RANGER (SERIES 10) FRONT STRUT
SERIES 10 A10RF50AB RANGER 500 6X6 (SERIES 10) FRONT STRUT
SERIES 10 C10CD50AA PTV 4X4 (SERIES 10) FRONT STRUT
SERIES 10 C10CD50AA PTV 4X4 (SERIES 10) SWING ARM-REAR GEARCASE MOUNTING
SERIES 10 C10RB42AA UTV 2X4 (SERIES 10) FRONT STRUT
SERIES 10 C10RD50AA UTV 4X4 (SERIES 10) FRONT STRUT
SERIES 11 A11RB42AA-A11RD50AA-AB-A11RF50AA RANGER (SERIES 11) FRONT STRUT
SERIES 11 C11RB42AA-C11RD50AA-AB-C11RF50AA UTV 2X4-4X4-6X6 (SERIES 11) FRONT STRUT
SERIES 11 C11RB63AA UTV 1500 2X4 (SERIES 11)(PPS) FRONT STR
Polaris 3514635, 40X74X40mm. Rear. Timken 510003. $28 plus shipping.
RockAuto
2013 D131D9JDJ-1L9JDJ-2M9JDJ BRUTUS-HD-HD PTO SUSPENSION, REAR
2014 D142M9JDJ-1L9JDJ-1D9JDJ-2D9JDJ BRUTUS HD HDPTO SUSPENSION, REAR
2015 D151DPD1AJ-2D-1L-1M-2M BRUTUS HD HDPTO SUSPENSION, REAR
1996 S969244 SWEDISH SPORTSMAN 500 REAR SUSPENSION
1996 W969244 SPORTSMAN 500 REAR SUSPENSION
1997 S97CH50E Swedish Sportsman 50 REAR SUSPENSION
1997 W97CD50A XPLORER 500 REAR SUSPENSION
1997 W97CH50A SPORTSMAN 500 REAR SUSPENSION
1998 S98CH50E SWEDISH SPORTSMAN 500 REAR SUSPENSION
1998 S98CH50EB SWEDISH SPORTSMAN 500 REAR SUSPENSION
1998 W98CH50A SPORTSMAN 500 REAR SUSPENSION
1998 W98CH50AB SPORTSMAN 500 REAR SUSPENSION
1998 W98CH50AC SPORTSMAN 500 REAR SUSPENSION
1998 W98CH50AD SPORTSMAN 500 REAR SUSPENSION
1998 W98CH50AE SPORTSMAN 500 REAR SUSPENSION
1998 W98CH50AF SPORTSMAN 500 REAR SUSPENSION
1999 A99CH33AA SPORTSMAN 335 REAR SUSPENSION
1999 A99CH33AB SPORTSMAN 335 REAR SUSPENSION
1999 A99CH33CA SPORTSMAN 335 REAR SUSPENSION
1999 A99CH33CB SPORTSMAN 335 REAR SUSPENSION
1999 A99CH33IA WORKER 335 REAR SUSPENSION
1999 A99CH45CA DIESEL REAR SUSPENSION
1999 A99CH45IA INTL DIESEL REAR SUSPENSION
1999 A99CH50AA SPORTSMAN 500 REAR SUSPENSION
1999 A99CH50AB SPORTSMAN 500 REAR SUSPENSION
1999 A99CH50AC SPORTSMAN 500 RSE REAR SUSPENSION
1999 A99CH50EA WORKER 500 REAR SUSPENSION
1999 A99CH50EB WORKER 500 REAR SUSPENSION
1999 A99RF50AA RANGER MIDDLE SHOCK MOUNTING
2000 A00CH33AA SPORTSMAN 335 REAR SUSPENSION
2000 A00CH33AB SPORTSMAN 335 REAR SUSPENSION
2000 A00CH33AC SPORTSMAN 335 REAR SUSPENSION
2000 A00CH33AD SPORTSMAN 335 REAR SUSPENSION
2000 A00CH33AE SPORTSMAN 335 REAR SUSPENSION
2000 A00CH33AF SPORTSMAN 335 REAR SUSPENSION
2000 A00CH33AG SPORTSMAN 335 REAR SUSPENSION
2000 A00CH46CA DIESEL REAR SUSPENSION
2000 A00CH50AA SPORTSMAN 500 REAR SUSPENSION
2000 A00CH50AB SPORTSMAN 500 REAR SUSPENSION
2000 A00CH50AC SPORTSMAN 500 RSE REAR SUSPENSION
2000 A00CH50AE SPORTSMAN 500 REAR SUSPENSION
2000 A00CH50AF SPORTSMAN 500 REAR SUSPENSION
2000 A00CH50AH SPORTSMAN 500 REAR SUSPENSION
2000 A00CH50AJ SPORTSMAN 500 RSE REAR SUSPENSION
2000 A00CH50AK SPORTSMAN 500 REAR SUSPENSION
2000 A00CH50AL SPORTSMAN 500 REAR SUSPENSION
2000 A00CH50EB SPORTSMAN 500 REAR SUSPENSION
2001 A01CH42AA SPORTSMAN 400 REAR SUSPENSION
2001 A01CH42AB SPORTSMAN 400 REAR SUSPENSION
2001 A01CH42AC SPORTSMAN 400 REAR SUSPENSION
2001 A01CH50AA SPORTSMAN 500 HO REAR SUSPENSION
2001 A01CH50AB SPORTSMAN 500 HO REAR SUSPENSION
2001 A01CH50AD SPORTSMAN 500 DUSE REAR SUSPENSION
2001 A01CH50AE SPORTSMAN 500 HO REAR SUSPENSION
2001 A01CH50AF SPORTSMAN 500 DUSE HO REAR SUSPENSION
2001 A01CH50AJ SPORTSMAN 500 RSE HO REAR SUSPENSION
2001 A01CH50AK SPORTSMAN 500 HO REAR SUSPENSION
2001 A01CH50EB WORKER 500 REAR SUSPENSION
2001 A10CH46CA DIESEL REAR SUSPENSION
2002 A02CH42AA SPORTSMAN 400 REAR SUSPENSION
2002 A02CH42AB SPORTSMAN 400 REAR SUSPENSION
2002 A02CH42AC SPORTSMAN 400 REAR SUSPENSION
2002 A02CH50 SPORTSMAN 500 ALL OPTIONS REAR SUSPENSION
2002 A02CH68AA-AB-AC-CA-CB SPORTSMAN 700 REAR WHEEL DRIVE
2003 A03CH42AA-AB-AC SPORTSMAN 400 REAR SUSPENSION
2003 A03CH42AA-AB-AC SPORTSMAN 400 REAR WHEEL DRIVE
2003 A03CH50AA-AB-AC-AD-AE-AH-AJ SPORTSMAN 500 HO REAR SUSPENSION
2003 A03CH50AA-AB-AC-AD-AE-AH-AJ SPORTSMAN 500 HO REAR WHEEL DRIVE
2003 A03CH59AA SPORTSMAN 600 REAR WHEEL DRIVE
2003 A03CH68AA-AC-AF-AH-AL SPORTSMAN 700 REAR WHEEL DRIVE
2004 A04CH42AA SPORTSMAN 400 REAR SUSPENSION
2004 A04CH42AA SPORTSMAN 400 REAR WHEEL DRIVE
2004 A04CH42AQ SPORTSMAN 400 REAR SUSPENSION
2004 A04CH42AQ SPORTSMAN 400 REAR WHEEL DRIVE
2004 A04CH50AA SPORTSMAN 500 REAR SUSPENSION
2004 A04CH50AA SPORTSMAN 500 REAR WHEEL DRIVE
2004 A04CH50AQ SPORTSMAN 500 REAR SUSPENSION
2004 A04CH50AQ SPORTSMAN 500 REAR WHEEL DRIVE
2004 A04CH59AF SPORTSMAN 600 REAR WHEEL DRIVE
2004 A04CH59AK SPORTSMAN 600 REAR WHEEL DRIVE
2004 A04CH68AC SPORTSMAN 700 REAR WHEEL DRIVE
2004 A04CH68AK SPORTSMAN 700 REAR WHEEL DRIVE
2004 A04CH68AU-CU SPORTSMAN 700 REAR WHEEL DRIVE
2004 A04RB42AA RANGER 2X4,4X4,6X6 MID DRIVE A-ARMS
2004 A04RB42AA RANGER 2X4,4X4,6X6 SWING ARM
2004 A04RB63AA RANGER TM SWING ARM
2005 A05MH42AB SPORTSMAN 400 REAR WHEEL DRIVE
2005 A05MH50AB SPORTSMAN 500 HO-INTL REAR WHEEL DRIVE
2005 A05MH59AK SPORTSMAN 600 REAR WHEEL DRIVE
2005 A05MH68AC SPORTSMAN 700 EFI REAR WHEEL DRIVE
2005 A05MH68AK-AN-AD SPORTSMAN 700 REAR WHEEL DRIVE
2005 A05MH68AP SPORTSMAN MV7 WHEEL, REAR
2005 A05MH76AC-AU-AW SPORTSMAN 800 EFI WHEEL, REAR
2005 R05RB50AA-RD50AA-AB-AC-AD-RF50AA-AB RANGER 2X4,4X4,6X6 MID DRIVE A-ARMS
2005 R05RB50AA-RD50AA-AB-AC-AD-RF50AA-AB RANGER 2X4,4X4,6X6 REAR SUSPENSION
2005 R05RB50AA-RD50AA-AB-AC-AD-RF50AA-AB RANGER 2X4,4X4,6X6 SWING ARM
2005 R05RB63AA RANGER TM SWING ARM
2005 R05RD68AA RANGER XP SUSPENSION, REAR
2006 A06MH46AA SPORTSMAN 450 WHEEL DRIVE, REAR
2006 A06MH50AA SPORTSMAN 500 HO WHEEL DRIVE, REAR
2006 A06MH50AQ SPORTSMAN 500 EFI WHEEL DRIVE, REAR
2006 A06MH50FB SPORTSMAN 500 HO INTL WHEEL DRIVE, REAR
2006 A06MH50FC SPORTSMAN 500 EFI INTL WHEEL DRIVE, REAR
2006 A06MH68AA SPORTSMAN 700 WHEEL DRIVE, REAR
2006 A06MH68AQ SPORTSMAN 700 EFI WHEEL DRIVE, REAR
2006 A06MH76AL SPORTSMAN 800 EFI WHEEL, REAR
2006 A06MN50AU SPORTSMAN X2 WHEEL DRIVE, REAR
2006 R06RB50AA RANGER 500 2X4-4X4 SUSPENSION, REAR
2006 R06RB63AA RANGER TM SWING ARM
2006 R06RD50AC RANGER 500 4X4 EFI SUSPENSION, REAR
2006 R06RD68AA RANGER XP 4x4 700 SUSPENSION, REAR
2006 R06RF68AA RANGER 6x6 EFI 700 A-ARMS, MID DRIVE
2006 R06RF68AA RANGER 6x6 EFI 700 SWING ARM
2007 A07MH46AA-AZ SPORTSMAN 450 WHEEL, REAR
2007 A07MH50AB-AL-AQ-AX-AY-AZ-MN50AF-AN-AT-AY SPORTSMAN 500 EFI WHEEL, REAR
2007 A07MH50FC SPORTSMAN 500 EFI INTL WHEEL, REAR
2007 A07MH68AX-AY-AZ SPORTSMAN 700 EFI WHEEL, REAR
2007 A07MH76AL-AQ-AX-AY-AZ-A2-MN76AF-AT-AY SPORTSMAN 800 EFI WHEEL, REAR
2007 A07MH76FA SPORTSMAN 800 EFI INTL WHEEL, REAR
2007 A07TH50AL-AQ-AU-AZ-TN50AF-AS-AU SPORTSMAN X2 500 EFI WHEEL, REAR
2007 A07TH50EA SPORTSMAN X2 500 EFI QUAD WHEEL, REAR
2007 A07TH76AU-TN76AF-AL-AU SPORTSMAN X2 800 EFI WHEEL, REAR
2007 R07RB50AA-RH50AA RANGER 500 2X4-4X4 SUSPENSION, REAR
2007 R07RF68AD-AF RANGER 700 EFI 6X6 A-ARMS, MID DRIVE
2007 R07RF68AD-AF RANGER 700 EFI 6X6 SWING ARM
2007 R07RH50AF-AR-AT RANGER 500 EFI 4X4 SUSPENSION, REAR
2007 R07RH68AD-AG-AH-AK-AL-AO-AP-AW RANGER 4X4 700 EFI-LE SUSPENSION, REAR
2008 A08DN50AF-AS-AW-AZ SPORTSMAN TOURING 500 EFI WHEELS, REAR
2008 A08DN50EA SPORTSMAN TOURING 500 EFI QUAD WHEELS, REAR
2008 A08DN76AF-AG-AH-AL-AJ-AS SPORTSMAN TOURING 800 EFI WHEELS, REAR
2008 A08DN76FC SPORTSMAN TOURING 800 EFI INTL WHEELS, REAR
2008 A08MH50AX-AZ SPORTSMAN 500 HO WHEELS, REAR TIRE and BRAKE DISC
2008 A08MH50SS-SQ SPORTSMAN 500 EFI SCANDINAVIAN WHEELS, REAR
2008 A08MH76SS-SF SPORTSMAN 800 EFI SCANDINAVIAN WHEELS, REAR
2008 A08MN50AF-AN-AQ-AR-AS-AT-AW-AX SPORTSMAN 500 HO EFI WHEELS, REAR
2008 A08MN76AF-AL-AQ-AR-AS-AT-AX SPORTSMAN 800 HO EFI WHEELS, REAR
2008 A08TN50AT-AX-AZ SPORTSMAN X2 500 EFI WHEELS, REAR
2008 A08TN50EA SPORTSMAN X2 500 EFI QUAD WHEELS, REAR
2008 A08TN68AX-AZ SPORTSMAN X2 700 EFI WHEELS, REAR
2008 A08TN76AA-AQ SPORTSMAN X2 800 EFI LE WHEELS, REAR
2008 R08RB50AA RANGER 500 2X4 SUSPENSION, REAR
2008 R08RF68AD-AF-AZ RANGER 6X6 700 EFI CHASSIS, SWING ARM
2008 R08RF68AD-AF-AZ RANGER 6X6 700 EFI SUSPENSION, A-ARMS, MID DRIVE
2008 R08RH50AF-AR-AT RANGER 4X4 500 EFI SUSPENSION, REAR
2008 R08RH68 RANGER 4X4 700 EFI-XP ALL OPTIONS SUSPENSION, REAR
2008 R08VH76AD-AG RZR 800 EFI WHEEL, REAR
2008 R08WH68AG-AH-AK-AR RANGER 4X4 700 EFI CREW SUSPENSION, REAR
2009 A09CL76AA SPORTSMAN 800 EFI 6X6 WHEELS, REAR
2009 A09DN50AB-AZ SPORTSMAN TOURING 500 EFI WHEELS, REAR
2009 A09DN50EA SPORTSMAN TOURING 500 EFI QUAD WHEELS, REAR
2009 A09DN76AB-AL-AY SPORTSMAN TOURING 800 EFI WHEELS, REAR
2009 A09DN76FC SPORTSMAN TOURING 800 EFI INTL WHEELS, REAR
2009 A09MH50AS-AX-AZ SPORTSMAN 500 HO WHEELS, REAR TIRE and BRAKE DISC
2009 A09MN50AN-AX SPORTSMAN 500 EFI WHEELS, REAR
2009 A09MN50ET SPORTSMAN 500 EFI TRACTOR WHEELS, REAR
2009 A09MN76AX-AZ SPORTSMAN 800 HO EFI WHEELS, REAR
2009 A09TN50AX-AZ SPORTSMAN X2 500 EFI WHEELS, REAR
2009 A09TN50EA SPORTSMAN X2 500 EFI QUAD WHEELS, REAR
2009 A09TN76AL-AX-AZ SPORTSMAN X2 800 EFI WHEELS, REAR
2009 R09HH50AG-AR RANGER 4X4 500 EFI SUSPENSION, REAR
2009 R09HH68-HY68 RANGER 4X4 700 EFI ALL OPTIONS SUSPENSION, REAR
2009 R09RB50AF RANGER 2X4 500 CARB SUSPENSION, REAR
2009 R09RF68AF-AR-AZ RANGER 6X6 700 EFI CHASSIS, SWING ARM
2009 R09RF68AF-AR-AZ RANGER 6X6 700 EFI SUSPENSION, A-ARMS, MID DRIVE
2009 R09VH76 RZR 800 EFI ALL OPTIONS WHEELS, REAR
2009 R09VH76AX RZR "S" 800 EFI WHEELS, REAR
2009 R09VH76FX RZR "S" 800 EFI INTL WHEELS, REAR
2009 R09WH68AC-AG-AH-AL-AR-AZ RANGER 4X4 700 EFI CREW SUSPENSION, REAR
2010 A10CL76AA SPORTSMAN 800 EFI 6X6 WHEELS, REAR
2010 A10DH50AX-AZ SPORTSMAN TOURING 500 HO WHEELS, REAR
2010 A10DH50FX SPORTSMAN TOURING 500 HO INTL WHEELS, REAR
2010 A10MH50AJ-AX-AZ SPORTSMAN 500 HO WHEELS, REAR TIRE and BRAKE DISC
2010 A10MH50FX-FF SPORTSMAN 500 HO INTL WHEELS, REAR TIRE and BRAKE DISC
2010 A10MH76AJ-MN76AX-AZ SPORTSMAN 800 EFI WHEELS, REAR
2010 A10MN50ET SPORTSMAN 500 EFI TRACTOR WHEELS, REAR
2010 R10HR76AG-AR RANGER 6X6 800 EFI SUSPENSION, A-ARMS, MID DRIVE and REAR DRIVE
2010 R10RC08GA-GH-FA-FH RANGER EV-INTL 4X4 SUSPENSION, REAR
2010 R10RH45AG-AH-AR RANGER 4X4 400 HO SUSPENSION, REAR
2010 R10TH50AG-AR RANGER 4X4 500 EFI SUSPENSION, REAR
2010 R10TH76-TY76 RANGER 4X4 800 EFI ALL OPTIONS SUSPENSION, REAR
2010 R10VH76 ALL OPTIONS-VY76AZ RZR 800 EFI WHEELS, REAR
2010 R10VH76AB-AO-AQ-AW RZR "S" 800 EFI WHEELS, REAR
2010 R10VH76FX RZR "S" 800 EFI INTL WHEELS, REAR
2010 R10WH76AG-AH-AR-AV-WY76AW-AZ RANGER 4X4 800 EFI CREW SUSPENSION, REAR
2010 R10XH76AA RZR 4 800 EFI WHEELS, REAR
2011 A11CF76AA SPORTSMAN 800 EFI 6X6 WHEELS, REAR
2011 A11DH50AX-AZ SPORTSMAN TOURING 500 HO WHEELS, REAR
2011 A11DH50FX SPORTSMAN TOURING 500 HO INTL WHEELS, REAR
2011 A11MB46FZ HAWKEYE 400 HO 2X4 WHEELS, REAR TIRE and BRAKE DISC
2011 A11MH46AX-AZ SPORTSMAN 400 HO 4X4 WHEELS, REAR TIRE and BRAKE DISC
2011 A11MH50AX-AZ SPORTSMAN 500 HO WHEELS, REAR TIRE and BRAKE DISC
2011 A11MH50FF SPORTSMAN FOREST 500 WHEELS, REAR TIRE and BRAKE DISC
2011 A11MH76AX-AZ SPORTSMAN 800 EFI WHEELS, REAR TIRE and BRAKE DISC
2011 A11MN50ET SPORTSMAN FOREST TRACTOR 500 EFI WHEELS, REAR
2011 R11HR76AG-AR RANGER 6X6 800 EFI SUSPENSION, A-ARMS, MID DRIVE and REAR DRIVE
2011 R11RC08GA-GH-FA-FH RANGER EV 4X4-INTL SUSPENSION, REAR
2011 R11RC08LG POLARIS LSV 4X4 SUSPENSION, REAR
2011 R11RH45AG-AH-AR RANGER 400 HO SUSPENSION, REAR
2011 R11RH50AG-AH-AR RANGER 4X4 500 EFI SUSPENSION, REAR
2011 R11TH76-TY76 RANGER 4X4 800 EFI ALL OPTIONS SUSPENSION, REAR
2011 R11TH90DG RANGER 4X4 900 D SUSPENSION, REAR
2011 R11VE76AC-AD-AT-AW-AZ RZR "S" 800 EFI WHEELS, REAR
2011 R11VH76-VY76 RZR 800 EFI-EPS ALL OPTIONS WHEELS, REAR
2011 R11VM76FX RZR S EPS INTL WHEELS, REAR
2011 R11WH50AG-AH-AR RANGER 4X4 500 CREW SUSPENSION, REAR
2011 R11WH76AG-AR-WY76AE-AH-AJ RANGER 4X4 800 EFI CREW SUSPENSION, REAR
2011 R11XH76AW-AZ-XY76AA RZR 4-EPS RGE WHEELS, REAR
2011 R11XY76FX RZR 4 INTL WHEELS, REAR
2012 A12CF76AA SPORTSMAN 800 EFI 6X6 WHEELS, REAR
2012 A12CF76FF SPORTSMAN FOREST 800 6X6 WHEELS, REAR
2012 A12DH50AX-AZ SPORTSMAN TOURING 500 HO WHEELS, REAR
2012 A12MB46FZ HAWKEYE 400 HO 2X4 WHEELS, REAR TIRE and BRAKE DISC
2012 A12MH46AF-AX-AZ SPORTSMAN 400 HO 4X4 WHEELS, REAR TIRE and BRAKE DISC
2012 A12MH50AD-AO-AQ-AX-AZ SPORTSMAN 500 HO WHEELS, REAR TIRE and BRAKE DISC
2012 A12MH50FF-FX-FY SPORTSMAN FOREST 5OO WHEELS, REAR TIRE and BRAKE DISC
2012 A12MH76AD-AX-AZ SPORTSMAN 800 EFI WHEELS, REAR TIRE and BRAKE DISC
2012 A12MH76FF SPORTSMAN FOREST 800 WHEELS, REAR TIRE and BRAKE DISC
2012 A12MN50ET-EX SPORTSMAN FOREST TRACTOR 500 WHEELS, REAR
2012 A12MN50ET-EX SPORTSMAN FOREST TRACTOR 500 WHEELS, REAR TIRE and BRAKE DISC
2012 R12HR76AG-AR RANGER 6X6 800 SUSPENSION, A-ARMS, MID DRIVE and REAR DRIVE
2012 R12RC08GA-GH-FA-FH RANGER EV-LEV 4X4 SUSPENSION, REAR
2012 R12RC08LG POLARIS LSV 4X4 SUSPENSION, REAR
2012 R12RH45AG-AH-AR RANGER 400 4X4 SUSPENSION, REAR
2012 R12RH50AG-AH-AM-AR-AZ RANGER 500 4X4 SUSPENSION, REAR
2012 R12TH76-TH7E-TX7E RANGER XP 800 SUSPENSION, REAR
2012 R12TH90DG RANGER 900 DIESEL SUSPENSION, REAR
2012 R12VE76AB-AD-AE-AJ-AO RZR S 800 EFI WHEELS, REAR
2012 R12VE76FX-FI RZR S INTL-ISRAEL WHEELS, REAR
2012 R12VH57AD RZR 570 EFI WHEELS, REAR
2012 R12VH57FX RZR 570 EFI INTL WHEELS, REAR
2012 R12VH76AB-AD-AF-AH-AI-AJ-AM-EAB-EAS RZR 800 EFI-EPS WHEELS, REAR
2012 R12WH50AG-AH-AK-AR RANGER 500 4X4 CREW SUSPENSION, REAR
2012 R12WH76AG-AR-EAH-EAV-EAW RANGER CREW 800 SUSPENSION, REAR
2012 R12WH90DG RANGER 4X4 900 DIESEL CREW SUSPENSION, REAR
2012 R12XE76AD-7EAB-EAO RZR 4 800 EFI WHEELS, REAR
2012 R12XE7EFX RZR 4 800 EFI EPS INTL WHEELS, REAR
2013 A13CF76AA SPORTSMAN 800 EFI 6X6 WHEELS, REAR
2013 A13CF76FF SPORTSMAN FOREST 800 6X6 WHEELS, REAR
2013 A13DH50AX-AZ SPORTSMAN TOURING 500 HO WHEELS, REAR
2013 A13MB46FZ HAWKEYE 400 HO 2X4 WHEELS, REAR TIRE and BRAKE DISC
2013 A13MB46TH HAWKEYE 400 HO 2X4 HD WHEELS, REAR TIRE and BRAKE DISC
2013 A13MH46AF-AX-MS46AX SPORTSMAN 400 HO 4X4 WHEELS, REAR TIRE and BRAKE DISC
2013 A13MH50AJ-AQ-AX-AZ SPORTSMAN 500 HO WHEELS, REAR TIRE and BRAKE DISC
2013 A13MH50FF-FJ-FU SPORTSMAN FOREST 500 WHEELS, REAR TIRE and BRAKE DISC
2013 A13MH50TD SPORTSMAN 500 HD WHEELS, REAR TIRE and BRAKE DISC
2013 A13MH76AD-AX-AZ SPORTSMAN 800 EFI WHEELS, REAR TIRE and BRAKE DISC
2013 A13MH76FF SPORTSMAN FOREST 800 WHEELS, REAR TIRE and BRAKE DISC
2013 A13MN50ET-EX SPORTSMAN FOREST TRACTOR 500 WHEELS, REAR
2013 A13MN50ET-EX SPORTSMAN FOREST TRACTOR 500 WHEELS, REAR TIRE and BRAKE DISC
2013 R13HR76AG-AR RANGER 6X6 800 SUSPENSION, A-ARMS, MID DRIVE and REAR DRIVE
2013 R13RC08GA-GH-FA-FH RANGER 48V EV MIDSIZE-INTL SUSPENSION, REAR
2013 R13RH45AG RANGER 400 MIDSIZE SUSPENSION, REAR
2013 R13RH50AG-AH-AM-AR RANGER 500 MIDSIZE SUSPENSION, REAR
2013 R13RH76AG-AH-AN RANGER 800 EFI MIDSIZE SUSPENSION, REAR
2013 R13TH76-7E RANGER 800 EFI SUSPENSION, REAR
2013 R13TH90DG RANGER 900 DIESEL SUSPENSION, REAR
2013 R13UH88-UH9E RANGER 900 XP ALL OPTIONS SUSPENSION, REAR
2013 R13VE76AD-AI-AW-7EAS-EAT RZR S 800 EFI WHEELS, REAR
2013 R13VE76FX-FI RZR S 800 EFI INTL-ISRAEL WHEELS, REAR
2013 R13VH57AD-6EAK RZR 570 EFI WHEELS, REAR
2013 R13VH57FX RZR 570 EFI INTL WHEELS, REAR
2013 R13VH76AC-AD-AN-AS-EAI RZR 800 EFI WHEELS, REAR
2013 R13WH50AG-AH-AR-AX RANGER 500 CREW MIDSIZE SUSPENSION, REAR
2013 R13WH76AG-AR-EAH-EAI RANGER 800 CREW SUSPENSION, REAR
2013 R13WH90DG RANGER CREW 900 DIESEL SUSPENSION, REAR
2013 R13XE76AD-EAI RZR 4 800 EFI WHEELS, REAR
2014 A14BH33AJ SPORTSMAN ACE WHEELS, REAR
2014 A14BH33FJ SPORTSMAN ACE EURO WHEELS, REAR
2014 A14CF76AA SPORTSMAN 800 EFI 6X6 WHEELS, REAR
2014 A14CF76FA SPORTSMAN 800 EFI 6X6 FOREST WHEELS, REAR
2014 A14DH57AA-AJ SPORTSMAN TOURING 570 EFI WHEELS, REAR TIRE and BRAKE DISC
2014 A14DH57FJ SPORTSMAN TOURING 570 EFI INTL WHEELS, REAR TIRE and BRAKE DISC
2014 A14MB46TH HAWKEYE 400 HO 2X4 HD WHEELS, REAR TIRE and BRAKE DISC
2014 A14MH46AA-AH-MS46AA SPORTSMAN 400 HO 4X4-SE WHEELS, REAR TIRE and BRAKE DISC
2014 A14MH57AA-AC-AD SPORTSMAN 570 EFI WHEELS, REAR TIRE and BRAKE DISC
2014 A14MH57FA-FJ SPORTSMAN 570 FOREST WHEELS, REAR TIRE and BRAKE DISC
2014 A14MH57TD SPORTSMAN 570 EFI HD WHEELS, REAR TIRE and BRAKE DISC
2014 A14MH5EAA-EAC-EAJ SPORTSMAN 570 EFI EPS WHEELS, REAR TIRE and BRAKE DISC
2014 A14MH5EFJ-EFK SPORTSMAN 570 EFI EPS FOREST WHEELS, REAR TIRE and BRAKE DISC
2014 A14MH76AA-AH SPORTSMAN 800 EFI WHEELS, REAR TIRE and BRAKE DISC
2014 A14MH76FD SPORTSMAN 800 EFI FOREST WHEELS, REAR TIRE and BRAKE DISC
2014 A14MN50EM-EA SPORTSMAN FOREST TRACTOR 500 WHEELS, REAR
2014 A14MN50EM-EA SPORTSMAN FOREST TRACTOR 500 WHEELS, REAR TIRE and BRAKE DISC
2014 A14MX5ETH SPORTSMAN 570 EFI UTE HD EPS WHEELS, REAR TIRE and BRAKE DISC
2014 R141D9JDA-2D9JDA RANGER DIESEL HST-DELUXE SUSPENSION, REAR
2014 R14HR76AA-AJ RANGER 800 6X6 SUSPENSION, A-ARMS, MID DRIVE and REAR DRIVE
2014 R14RC08GD-GJ-FJ RANGER EV MIDSIZE-INTL SUSPENSION, REAR
2014 R14RH45AA RANGER 4X4 400 SUSPENSION, REAR
2014 R14RH57AA-AC-AR-6EAZ RANGER 570 EFI SUSPENSION, REAR
2014 R14RH57FX RANGER 570 INTL SUSPENSION, REAR
2014 R14RH76AA-76AC-7EAZ RANGER 800 EFI MIDSIZE SUSPENSION, REAR
2014 R14TH76AA-AC-EAS-AAC-ACC-EASC RANGER 800 SUSPENSION, REAR
2014 R14TH90DG RANGER 900 DIESEL SUSPENSION, REAR
2014 R14TH90FX RANGER DIESEL INTL SUSPENSION, REAR
2014 R14UH88-9E-9EAN-9EAI-9EAIC RANGER XP 900 ALL OPTIONS SUSPENSION, REAR
2014 R14WH57AA-AC-AR-6EAT RANGER CREW 570 EFI SUSPENSION, REAR
2014 R14WH76AA RANGER 800 CREW SUSPENSION, REAR
2014 R14WH88A-9EA RANGER 900 CREW ALL OPTIONS SUSPENSION, REAR
2014 R14WH90DG RANGER CREW 900 DIESEL SUSPENSION, REAR
2014 R14WH9EMD RGR 4X4 900D HIPPO MPS SUSPENSION, REAR
2014 Z14VE76AD-7EAL-7EAW-7EAJ-7EAU RZR S 800 WHEELS, REAR
2014 Z14VE76FX-FI RZR S 800 INTL EFI-ISRAEL WHEELS, REAR
2014 Z14VH57AD-6EAI-6EAW RZR 570 WHEELS, REAR
2014 Z14VH76AC-AD-EAI-EAK-EAJ-EAL-EAW RZR 800 WHEELS, REAR
2014 Z14XE7EAL-X RZR 4 800 WHEELS, REAR
2015 A15DAA32AA-AJ SPORTSMAN ACE 325 EFI WHEELS, REAR
2015 A15DAA32EA-EJ SPORTSMAN ACE 325 EURO WHEELS, REAR
2015 A15DAA57AJ-AH-EAK SPORTSMAN ACE 570 EFI WHEELS, REAR
2015 A15DAA57EJ-EH-EEK SPORTSMAN ACE 570 EURO WHEELS, REAR
2015 A15DAH32EJ SPORTSMAN ACE 325 HD WHEELS, REAR
2015 A15DAH57EJ SPORTSMAN ACE 570 HD WHEELS, REAR
2015 A15S6A76FA FOREST 800 6X6 WHEELS, REAR
2015 A15SAA32EH HAWKEYE 325 2X4 WHEELS, REAR TIRE and BRAKE DISC
2015 A15SDA57AA-LJ-E57AJ SPORTSMAN TOURING 570 EFI-EPS WHEELS, REAR TIRE and BRAKE DISC
2015 A15SDA57FH SPORTSMAN 570 EFI TOURING EU WHEELS, REAR TIRE and BRAKE DISC
2015 A15SDA57HH-HA SPORTSMAN TOURING 570 EFI MD WHEELS, REAR TIRE and BRAKE DISC
2015 A15SEA32AA-AH SPORTSMAN ETX EFI WHEELS, REAR TIRE and BRAKE DISC
2015 A15SEA32HA SPORTSMAN ETX EFI MD WHEELS, REAR TIRE and BRAKE DISC
2015 A15SEA57AA-AC-AD-LD SPORTSMAN 570 EFI WHEELS, REAR TIRE and BRAKE DISC
2015 A15SEA57HA SPORTSMAN 570 EFI MD WHEELS, REAR TIRE and BRAKE DISC
2015 A15SEB57CA-CJ-SEC57CJ-CA SPORTSMAN 570 EFI EPS FOREST QUAD WHEELS, REAR TIRE and BRAKE DISC
2015 A15SEE57AA-AC-AJ SPORTSMAN 570 EFI EPS WHEELS, REAR TIRE and BRAKE DISC
2015 A15SEE57HJ-HA SPORTSMAN 570 EFI EPS MD WHEELS, REAR TIRE and BRAKE DISC
2015 A15SEH57AD SPORTSMAN 570 HD WHEELS, REAR TIRE and BRAKE DISC
2015 A15SET57CA-S57CJ-CA 570 EFI-EPS FOREST TRACTOR WHEELS, REAR TIRE and BRAKE DISC
2015 A15SHC57CS SPORTSMAN 570 SP EPS, QUAD WHEELS, REAR TIRE and BRAKE DISC
2015 A15SHD57AC-E57AS-AM-L57AK SPORTSMAN 570 SP WHEELS, REAR TIRE and BRAKE DISC
2015 A15SHE57HS SPORTSMAN 570 SP MD WHEELS, REAR TIRE and BRAKE DISC
2015 A15SHS57CS SPORTSMAN 570 SP EPS, TRACTOR WHEELS, REAR TIRE and BRAKE DISC
2015 A15SJE57AS-AV SPORTSMAN 570 SP TOURING WHEELS, REAR TIRE and BRAKE DISC
2015 A15SJE57HI 570 TR PRM PS MD WHEELS, REAR TIRE and BRAKE DISC
2015 A15SUH57AH SPORTSMAN 570 EFI UTE HD WHEELS, REAR TIRE and BRAKE DISC
2015 A15SWE57AA-AD SPORTSMAN 570 EFI X2 EPS WHEELS, REAR TIRE and BRAKE DISC
2015 A15SWE57FA SPORTSMAN 570 EFI X2 EPS EUROPE WHEELS, REAR TIRE and BRAKE DISC
2015 R151DPD1AA-2D RANGER HST SUSPENSION, REAR
2015 R15RAA76AA-AJ RGR 800 6X6 SUSPENSION, A-ARMS, MID DRIVE and REAR DRIVE
2015 R15RMA32AA-AJ RANGER ETX SUSPENSION, REAR
2015 R15RMA32FA RANGER ETX EU SUSPENSION, REAR
2015 R15RMA57AA-AR-AZ-AC-LA-H57AR RGR 570 SUSPENSION, REAR
2015 R15RMA57FA RGR 570 EU SUSPENSION, REAR
2015 R15RMAE4GJ-GC-EJ RANGER EV SUSPENSION, REAR
2015 R15RNA57AA-AC-AR-E57AS RGR 570 EFI CREW SUSPENSION, REAR
2015 R15RTA-E87 RGR 900 XP ALL OPTIONS SUSPENSION, REAR
2015 R15RTA57AA-AR-AC-EAU RGR 570 FULL SIZE SUSPENSION, REAR
2015 R15RTAD1AA-EA-ED1EA RANGER 1000 DIESEL SUSPENSION, REAR
2015 R15RTAD1FA RANGER 1000 DIESEL EU SUSPENSION, REAR
2015 R15RUA57AA-E57AC RGR 570 EFI FULL SIZE CREW SUSPENSION, REAR
2015 R15RUA87-E87-YAA-ZAC RANGER CREW 900 ALL OPTIONS SUSPENSION, REAR
2015 R15RUAD1AA RANGER 1000 DIESEL CREW SUSPENSION, REAR
2015 Z15VHA57AJ-E57AS-AK RZR 570 WHEELS, REAR
2015 Z15VHA57FJ RZR 570 EU WHEELS, REAR
SERIES 10 A10RB42AA RANGER (SERIES 10) SWING ARM
SERIES 10 A10RD50AA RANGER (SERIES 10) SWING ARM
SERIES 10 A10RF50AB RANGER 500 6X6 (SERIES 10) MID DRIVE A-ARMS
SERIES 10 A10RF50AB RANGER 500 6X6 (SERIES 10) SWING ARM
SERIES 10 C10RB42AA UTV 2X4 (SERIES 10) SWING ARM
SERIES 10 C10RD50AA UTV 4X4 (SERIES 10) SWING ARM
SERIES 11 A11RB42AA-A11RD50AA-AB-A11RF50AA RANGER (SERIES 11) MID DRIVE A-ARMS
SERIES 11 A11RB42AA-A11RD50AA-AB-A11RF50AA RANGER (SERIES 11) SWING ARM
SERIES 11 C11RB42AA-C11RD50AA-AB-C11RF50AA UTV 2X4-4X4-6X6 (SERIES 11) MID DRIVE A-ARMS
SERIES 11 C11RB42AA-C11RD50AA-AB-C11RF50AA UTV 2X4-4X4-6X6 (SERIES 11) SWING ARM
SERIES 11 C11RB63AA UTV 1500 2X4 (SERIES 11)(PPS) SWING ARM
Discussion Starter #16
That's awesome. What a list!!!!
As I was researching this I found that a napa fw14 is also good.
The Polaris bearing number is different but the cross referenced bearing list above matches.
Any ideas?
Discussion Starter #17
Polaris bearing number my finger is covering is 3514342. Doh
Discussion Starter #18
So I replaced the bearing with the all balls brand. I am gonna see how these hold up. If I have problems I will get the good ones.
I also changed out the a arm bushings in the front as well. When I had it all back together with new bearings and bushings I notice my front a arm moves forward and aft slightly when rocked forward and aft. I do believe my stock bushing did the same thing but was wondering if anyone else has noticed this? Also is there anyone out there that can jack their front up and check and see if theirs move forward and aft. The movement is right at where the a arm bolts to the frame.
Thx !!
Discussion Starter #20
That's weird. They shouldn't fail that quick.
1 - 20 of 21 Posts
