I have a 2012 Sportsman 400 HO. It was great until, after having it a couple years, my kid and his friends decided to thrash it. It has just a at for many years and I’ve decided to see if I can get it running. There is a fuel line that isn’t connected to anything and I can’t figure out where it goes. Can any of y’all help? (And, please, type slowly...I’m not super mechanical and know nothing about the ATV.) TIA
View attachment 151233 View attachment 151234 View attachment 151235
to the forum
Your question has now been logged into the queue and the next available forum member will answer you shortly. You will be given more advice than you could hope for.
The line may not be routed as it originally was and the carb does not to appear to be the original (original carb float bowl did not have lugs for mounting the carb to a gang of multiple carbs) - the line appears to be the transmission vent line and was simply routed high up on the frame to prevent water from entering the gear case. It was typically simply zip tied to an upper frame rail.
