I cannot find the fuel filter in my 2014 ranger 570 efi ?
Anybody that can tell me where it would be? Tgank you
So the whole unit would need to be replaced? Im nit even sure whats wrong witb it. It was running fine and backfired and stalled out now only runs with foot on gas.. Stalls out when idling
Well......... The problem is probably not the fuel filter. When a filter clogs, it won't run at speed, but usually runs fine at low speed. It sounds like it's rich at low speed and throttling up leans it out. You probably need to take it to a dealer so they can run the diagnostics on the EFI
May be the fuel pedal vane sensor #4 bad or loose. I'd also swap out the efi relay and check battery condition and charging system output. If no luck you'll need a Digital Wrench checkup.
137150
