1 - 11 of 11 Posts
hey guys
pulled my relay out by gas filler neck and 1 tab was rotted off..
(i was having intermittant power steering) and now dealer wants
to sell me an updated relay ket that needs to be hard wired into
harness ?? i asked just for the relay and they cant find the part ??
the numbers on the relay were half damaged when removing..
any help with replacement part would be appreciated..
also from my previous post--i had to replace my rear diff;the pinion
shaft had teeth like a swordfish..ouch..
THANKS ROB
2012 ORANGE 850 XP EPS--650 MILES ON IT--:fuercht:
Sorry I do not have PS to give you numbers... Your gonna need the electrical requirements for the relay then search places like Raido Shack and maybe eBay.
I toasted a relay in my winch couple years back. Factory part was like fifty bucks for under twenty shipped I bought ALL the relays and had them shipped to me! I changed them all and kept old as spares.
BUT you need the electrical requirements for the relay. Popo don't make relays, they buy them and you can too for a lot less that factory part!
thanks for the response
i'm sure someone will chime in who had the same problem..and
where to get the relay or part #..
cheers.rob.
I've seen some threads on here about a work around on the factory relay for under $5 with something you can get at the local auto parts store IIRC. Do a little searching on here and I bet it will pop up.
i did the search but couldnt find a place to buy-there is
an update for the part but no relay..
the part # is 871-1a-s-r1--i just need this relay..
someone else may chime in with an answer.
thanks.rob.
What you really need to cross reference is style, (two, four or five pole) volts and amps of the relay...
Remember a relay don't know if it's on a winch, light or on a power steering unit in a quad. ;)
Discussion Starter · #7 ·
hey guys
based all the searches etc..the only way to bye
is direct from china in bulk..i'll guess i'll remove my
snorkle kit and rad relocate kit and front plastic
to access harness and hardwire 2013 update relay
harness assembly..no choice..fun.fun.fun..
thanks.rob.
I just had to replace my power steering relay and I took the old one to NAPA and they cross referenced one and it works great. I also put a lot of dielectric grease on that bad boy so hopefully it doesn't corrode like that again.
Discussion Starter · #9 ·
hey man
thanks for the info..i'll give that a shot..
i found an electronics place in texas to order;mouser
electronics..but i'll try this first..
cheers..rob..
Got a part # for it. I also need a relay. thanks
hey man
cheers..rob..
When you reinstall it,......slather it with dielectric grease
1 - 11 of 11 Posts
