???? yeah that`s cute !!!!!opcorn:
Dig the stick out of your ass!if you can`t respect what others post or ask on here you need to find another place to spend your time. yeah I know I hear it a lot, there is a place to search what you`re looking but you may not find exactly what you are looking.thanks that`s my .02 :yahootongue:
So what are you looking for? This topic has been beat to death. "there is a place to search", yeah use it. If you don;t know how to use, don;t take it out on others. You can keep your two cents too.if you can`t respect what others post or ask on here you need to find another place to spend your time. yeah I know I hear it a lot, there is a place to search what you`re looking but you may not find exactly what you are looking.thanks that`s my .02 :yahootongue:
Just courious on why u add stabile every fill up? And seafoam so often or don't the wheeler get a lot of use so your just keeping the gas cleanI use 87 octane ..but I use top tier gas...shell..exxon..bp...texaco...and few others...they have detergent additives an stabilizers....but I still add Marine stable every fill an also seafoam about twice a month to add extra cleaning...but recently my mechanic has switched from sea foam to a product by STP...he claims you can actually notice a difference when used.....I am still a sea foam guy..but will try this..its cheaper also...
Motor Treatment by STP® | Multipurpose Motor Treatment
any auto parts....even lowes carries it.....Adavanced Auto is running a special this week....buy one an half off the other...I have to buy by the gallon..I use it my chainsaws...chippers...power equipment..trucks..cars...list goes onok thanks to the guys that don't mind replying.....seems like a lot of you are running 87 with sea foam, where is the best place to get it. thanks
Please tell us how the gas gets warmed as you use it. The gas gets burned as you use it, and no additive is needed in a machine that gets daily use....periodthe wheeler gets used daily...in rain..snow..mud...the gas get warmed as you use it...then when its shut off it cools..an can condensate..plus ethanol is a moisture sponge I have seen phase seperation in gas in less than a week untreated...ever see a gas can swell in heat an get sucked in after it cools...check the gas...I run the sea foam to keep the internals clean mostly..rings..valves..carb...
ever use sea foam to de carb a car engine an clean it..run a can thru your vac line going to brake booster till it stalls...then let it set 30 minutes...start it....smokes like you never seen....burns off all the carbon inside...but then you MUST change oil after...
