Just finished installing engine and was adding antifreeze seems I might have lost a hose? At least I do not remember taking one off of there. It is right behind the water pump. When looking from right footwell with the small right side panel off. The nipple is right above the foot brake cylinder.
Can someone have a look at theirs and see if there is a hose and where it goes to? Thanks.
Discussion Starter #2
Seems like every pic of it in the service manual has no hose on it. But when I started filling antifreeze got about quart and just a bit more noticed it was dripping from there. So it has to have a hose connected to it?
Looks like the weep hole.
It identifies the bearing and/or seal is bad.
Time for a new water pump.
Could also be the bypass hose. Hard to tell from the pic.
