1 - 20 of 23 Posts
Looks like you can use the rear holes in the back rack to mount whips. I mounted my lighted whip but I dont like how it flexes the plastic and looks like it will break around the screw that is closest from stress and movement. Has anyone else tried mounting a whip there?
Not yet, I just looked to see where it mounts but haven't put it on. I might make one on my cooler rack instead.
That would be better. I'm thinking of adding a rear bumper to mount mine on instead
Polaris sells a Lock and Ride Whip mount i believe.
I didnt even think of that. I look and see. Thanks
I had two tribal whips break at the top of the mount. Needs a spring or something.
I put these quick release flag holders on our quads. When were done we just take them off. They bolt up using the same hole on the back and our bags can still stay on!!
You managed to break two Tribal LED whips? or just standard fiberglass whips in the adapter mount?
If you broke the LED whips, I'm really curious how? My whip takes a beating but still going strong!
Ok I will bite! Where can I get one like that!
Cagecam,
Don't want to get off topic, but which box is that on your rear rack? Does the gas container on top connect directly to the lid?
Thanks,
Nick
can I ask why people ride with a whip..are they required on some trails...or is just something you just do....some of the areas I ride has lots of over head branches and trees due to a tornado and the whip would hit them all....I see lots who ride desert trails use them...
Some areas require them for safety. They allow for better visibility of where a rider is when behind a hill, dune, etc.
Thanks...I sorta figured that...I ride mostly private land..will ride some parks in NH this spring..why I asked
I don't think NH requires them. I've been pulled for a registration check and they didn't say anything, you might be ok.
Sand dunes require it. And some trail areas do for added safety.
Nick I have the Polaris lock and ride box and I mounted the rotopac fuel jugs to the top. Works great for me
1 - 20 of 23 Posts
