Im looking for a sportsman 800 2005 Lift kit 6+ Inches with axles. Gorilla says it will be weeks and superATV is devoloping a new kit. Was hoping someone knows of a company who currently has them ready to sale?
Just ordered the kit glow in the dark white. Tons of rake tons of lift and wider!
Cant wait. This mated with my new 29.5 outlaw 2s on kore wheels and qsc clutch kit. This florida mud wont stand a chance!
I guess I need to make a build thread. Worst part is kit will be done probably this week. Axles on the other hand will take 2-3 weeks. this kit uses a custom +3 axle
You were right. Broke it this weekend. Have not tore it out yet. But 4wd is locked in. Im sure thats what happened. Seems no one makes a upgraded one for my 05 800? Suprratv says theres will not fit. Any advise here?
Hey folks, new to forum and a new owner of above vehicle. I've owned all sorts of toys but this is my first atv. It kinda fell on my lap. Could use some help, I put new plugs gave the carbs a thorough clean and fixed a leaky fuel line. Machine starts and idles fine but when I go to put some...
I have a 1998 Polaris Sportsman that the radiator over heats after 10 minutes on idle. I checked water pump spins when motor running. Replace fan, radiator and heat sensor. I jumped out the fan and works no issues.
Where do I go from here? I've replaced everything
So I need to replace the radiator on my wife's ATV. I don't want to pay $300-400 for an OEM radiator as that's a rip off. Has anyone used an aftermarket radiator with success that was in the $100-200 price range? If so can you let me know details on the radiator you purchased? If you have it's...
I have a 2018 pheonix with only 20 hrs and it makes a squealing noise and stops pulling whenever going up a steep hill which is very dangerous for my son. With that said now the quad will barley move at full throttle. Bought it used so no warranty.
has anyone had this problem before I spend the...
Ok so I installed a reman long block (800) and after running the engine 3-4 hours the dip stick pushed it's way out of the tube. Oil poured out and I topped it off and reinstalled the same dip stick. I either didn't get the latch latched or when I installed the crank case valve I put it in wrong...
