Thank you. How wide of a spacer did you use?I put 28/9/12 tires on the front of my 07 sportsman 800 and they were rubbing the rubber of the tire rod ends, I had to put spacers on mine
Thank you. I assume I willl need the same.Just ran outside, they are 1 1/2"
Thank you for the ideas. I will add 2 spacers to the list.If you do not want to run the spacers you can also flip your tie rod ends to allow the room for a 9" tire. Otherwise a 1.25" or larger spacer is needed.
Thanks. Ultimtly, I would like to get a set os SS 216 also, will see how money allows. May get tires firxt, or wait it out and get them both.When I ran my spacers on the front my front tires where also wider than my rear tires and to some this was very odd looking and after i didnt like the tires i replaced them with new rims and tires to the ones I got now. Some also add a smaller spacer in the rear to offset the difference of adding them in the front. I believe i have a set of spacers in the garage that i used for a week if you need pictures.
Do you have a pic of your quad from the front with the spacers?
Thanks,
Will
2012 Sportsman 400HO.
Thank you so much. I like the look of that. I think I will do the HL coils, thenget tires, and a clutch kit. Can get the fancy rims later on.Thank you. I assume I willl need the same.Just ran outside, they are 1 1/2"
Thanks,
Will
2012 Sportsman 400HO.![]()
I did 1 1/2" on all corners. I noticed better stability with the spacers too. I had to buy a 60" plow for mine since the next lower size was not as wide as the wheel base with the spacers installed
