You will have to look at tire sizes. Specifically the rear wheel size. I thing the fronts on all those machines are a 12" wheel with a 4/156 bolt pattern. The rear on the '02 is probably a 10" which tells me 4/4 bolt pattern. If the Scrambler is a 10" rear then it should bolt on. 2x4 and 4x4 will make a difference too so you will need to watch tire sizes.
I am not familiar with every Polaris model but I thing the Trail Blazer was a 2x4 sport machine, so you should be good to go. I think in 2002 the Trail Blazer was a 325 engine while the Scrambler was 400 or 500. You are probably adding some rolling weight to the smaller machine but it should work.
