I have a 2011 Ranger 800 LE. I am wanting to get a set of Bighorns. My stock tires are 26 x 11 x 12 and the Bighorns are 26 x 12 x 12. I was wondering if they will fit with no problem or if they are going to rub? The fronts should be fine I would think, going back with 26 x 9 x 12. Thanks for any help you can provide.
Look at the inside of your tires and see how much clearance you have all around. The 12" wide will be 1/2" wider to the inside than what's on there now. If you clear everything by an inch or more, they will fit no problem.
