On my 06 800, if my research is correct it has a 500w stator.. I will be running a 20" 120w led light bar, 35w HID's on the bumper lights & my boss cx150 150w amp powering 4 6.5" speakers? Or will I stress it/over power it? The time of all of them being on at the same time will be short.
You will not over stress the stator but you may drain the battery. If the stator delivers 500 watts to the battery you need to pull less than that from the battery. Otherwise the battery will go dead unless you put it on a battery tender between uses.
If it's not being riden, it's in the garage on my battery tender bank with the others & the lawnmowers. Thanks!
