1 - 11 of 11 Posts
Hey I have a question for all you guys in the know ! I have a 08 800 sportsman it only has the electric starter, if the starter ever quits while I am in the woods can it be towed to start it ?????
no. wont work.
the only thing you can do if you have tools with you, is remove the clutch cover and start it like you can a sled. put a rope around the clutch and give it a pull...might hurt like heck when it kicks back tho .
wow that doesnt sound like fun, alot of compression kicking back at ya. hopefully that never happens. the thought has went across my mind also.
note............keep an xtra fuse on hand n cause she blows .........
your best bet would be to call someone to jump start it.
Discussion Starter · #9 ·
I am not asking about a dead battery !!! Just want to know if towing it in gear will turn the engine, or will the rear braking system stop the wheels from turning ?? I mostly ride with others but we do go deep into the desert !!!
You "can not" tow start it!!! :deadhorse: :nono: But it would be nice if you could :yup:
if something happens to the starter, wether the battery is charged or not, you CAN NOT tow it to start it. It's been tested and failed. As a Polaris Mechanic....i sure do wish there was a way to make it work.
1 - 11 of 11 Posts
