1 - 2 of 2 Posts
Since you guys have been so much help in the past......1996 sportsman 500.
last fall I put a new belt on because I thought my problem was the belt. Now, I have a trip on the weekend and thought the problem was fixed until today. It will rev up in neutral as high as it should. pop it in to gear and it feels like you are going 2 mph. Same thing in reverse. Carb is cleaned, new belt, now what???
carb cleaned/
one thing i've noticed lately is that if you don't re-assemble the choke cable screw and throttle cable spring attached to carb...if they're not almost perfect, may cause issues! along with air / fuel screw. But, you had it working, and it quit again?
1 - 2 of 2 Posts
