its a 2006 500 x2 ho Polaris turn the key on sometimes it gets juice sometimes it don't you can hear noises when it does and a check engine light comes on sometimes it will even start but most of the time it wont any help will be thankfull just put a brand new battery in it
Sounds like your key switch needs to be cleaned out. If it works sometimes and not others then that is where I would start.
get a can of contact cleaner with a nozzle on it..insert in key hole an spray...then check the plug going to it..clean it an grease it...see if that helps..if not start checking from battery to pod for bad grounds an plugs
Welcome to the board!
