1 - 2 of 2 Posts
The engine in my 2002 Magnum 325 2x4 has been ruined, and I'm looking to replace it. I found an engine on Ebay from a 2000 Magnum 325 2x4, but I wasn't sure if it would be able to replace the 2002 engine.
Will it fit?
Click here to see the engine on Ebay
Thanks in advance for the help!
If I remember right the only difference would be in the valve cover design and the routing of the oil lines. Keep in mind that in 2000 Polaris had a service bulletin on 325 motors as the clamps on the oil lines would loosen up or fail causing the motors to seize. We warrantied a ton of these motors. I would be very cautious about buying that year motor online. Hope this helps - Good Luck!
1 - 2 of 2 Posts
