will this fix?
2220 Views 11 Replies 8 Participants Last post by  jsnance
1 - 12 of 12 Posts
Ouch! Anything can be fixed 🤣
The engine was new, what is the second piston size that can be used?
There are no over size pistons - I'd be more concerned with the engine cases and crankshaft.
What do you mean the engine was new? What break-in procedure did you use? What were you doing when it blew?
The bike was new, if I rectify the cylinders, what piston size can I use, and if that is not possible, where to buy only the repair of cylinders and pistons?
Buy the pistons from Polaris - send them along with the cylinders to US CHROME in Fondulac Wi - click HERE for their work order form - about $150 per cylinder or check the price of new parts from Polaris.
I would give you more detailed information, but you are keeping it a secret as to the year and model of what you destroyed. If you are not a qualified mechanic, you would be money ahead to buy a rebuilt engine from N-Flow and finally, if the ATV was NEW, why haven't you contacted the dealer to invoke warranty?
Reactions: 2
It kinda looks like it was run or forced to turn over with water in it. ????
Reactions: 1
From the looks of the muck around that engine, it looks like it was a deep mudder and ingested water and muck a full throttle. That is some pretty old looking grease and goo for a new engine.
D
Was new? is that one day after warranty ran out? the right side looks like the piston on my Express 400L 2 stroker after the automatic oiler stopped working over heated and blow head gasket which hydrolocked the piston. not realizing what caused the problem I replaced what was obviously broke and it happened again. Hopefully you already know what caused this.
OUCH!!! That hurts looking at it. Good luck brother
1 - 12 of 12 Posts
