95 Xplorer 400
Old regulator was 4 wire (Red, Yellow/Brown, Yellow/Red and Yellow)
I found a used replacement but it is slightly larger and has an additional wire. I ohmed it out and it is connected to the casing so I assume it is a ground.
Plugged it all in and ran at idle, about 12.3V on the +
Didn't rev to top but with a few cranks it didn't rise much so I assume it's OK.
Thoughts?
for sure. My concern was more about over-voltage as it was blowing lights bulbs all over.
The replacement regulator seems to be doing the job.
