I assume you have a winch mounting bracket? Take off front grill (4 torx heads) and isnbtall mount on winch and install winch in front. the mounting kit has 4 holes that will line up with the frame. I installed my contactor above the winch on the left side (as you are sitting on the ground looking at the front of the machine). There is a tab there that will line up with your contactor mounting holes. You will have a red power wire that is bundled up behind the front radiator..that is your prewired red power wire. that goes to the red on the contactor....the blue and yellow go from contactor to the winch, and then connect up your handlebar rocker switch. You will need to splice into a keyed power power. You will find two of these orange wires underneath the front fairing...open your storage box and it the middle part has 4 torx heads..take those off, and lift up and back...you will the wires underneath. Go back to your battery and you will find another red power wire bundled up....install that, along with the red one that is already on the battery and you are good to go
