The 850 are not prewired correct? Do you have to pre wire in order to hook the winch up to the battery, or can you just hook the winch up directly to the battery since its in the front rack?I think the XP touring LE modles come with the pure polaris 2500lb winch.. I have the same one on my touring.. Its the heaviest atv they make and its served me well for 3 years without failure if that helps you at all..
Have a 13 850 touring. What year is yours?I have the XP touring so I'm not much help in answering your question.. My touring came from the factory wired for a winch.. I seem to recall that some years of the regular xp did as well.. I don't remember when they stopped prewiring.. With the Touring, the battery is in the rear under the passenger seat.. The contactor is also mounted in the rear.. I imagine they stopped pre-wiring the 1-up XP's since the battery is right there in the front and easy to deal with..
It's easy to install, you'll need to order a mount plate, KFI is a great company that has the mount you will need. There is a contactor in the wiring, so it doesn't wire directly to the battery, the instructions will give you an idea, and you can usually find a site that has the mounting instructions. I also pulled up the Polaris instructions, there are mounting holes f the contactor on the front frame just behind the radiator.The 850 are not prewired correct? Do you have to pre wire in order to hook the winch up to the battery, or can you just hook the winch up directly to the battery since its in the front rack?I think the XP touring LE modles come with the pure polaris 2500lb winch.. I have the same one on my touring.. Its the heaviest atv they make and its served me well for 3 years without failure if that helps you at all..
Oh ok so will i have any problems installing the winch since its not pre wired?It's easy to install, you'll need to order a mount plate, KFI is a great company that has the mount you will need. There is a contactor in the wiring, so it doesn't wire directly to the battery, the instructions will give you an idea, and you can usually find a site that has the mounting instructions. I also pulled up the Polaris instructions, there are mounting holes f the contactor on the front frame just behind the radiator.The 850 are not prewired correct? Do you have to pre wire in order to hook the winch up to the battery, or can you just hook the winch up directly to the battery since its in the front rack?I think the XP touring LE modles come with the pure polaris 2500lb winch.. I have the same one on my touring.. Its the heaviest atv they make and its served me well for 3 years without failure if that helps you at all..
